#136
sounds interesting....
#137
![]() Tom |
#138
Can you say whether it will be NA or not?
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
#139
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
#140
NA all the way. My target numbers are about 140 hp higher @ the wheels, but with a superior torque spread.
Knowing that Frank Aragona makes 475 +/- crank hp from his carbureted drag-race EG33, I think this is feasible with ITB's and EFI. Bob |
#141
Bob |
#142
Which part number KRC pump? There appears to be three different part number. Thanks. -Bill
#143
Bob have you looked at the SVX manual on the cooling system. The reason I ask is I purchased a second hand SVX that had a Craig Electric water pump and the thermstate had been removed as well as the fins on the standard pump. I noticed the car ran hot even though the car temp said it was okay. The second clue there was a problem was that the heater did not work.
Looking at the SVX book you can see the cooling is close looped with water going around in a circle independent of the radiator till it heats up. Witht he electric water pump the water went in reverse on one part of the plumbing at ment the engine didn't get any cooling. In an attempt not to make this a long thread you need to block off the return pipes going from the engine to the water pump and don't run a thermostate. If you want I can explain this further if you are interested. Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#144
The page from the manal on cooling
#145
no offense.....But unless you have a power adder, these efficencies are not scientifically possible
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
#146
Bob |
#147
Which ones are you talking about? -Bill
#148
No offense taken. But why do you deem them 'not scientifically possible'? We're not building street engines here, we're talking about developing an engine for racing. In fact we're still only at about 110 hp per litre, which is nothing particularly outrageous for a fairly modern twin-cam 4-valve design engine without emissions concerns. Heck, I've made a 40-year old non-crossflow single cam 2-valve per cylinder engine put out 107 hp per litre for racing use...now that was a challenge!
#149
Thanks to Desertrunner for letting me know about this thread.
I've checked the NASIOC thread too. Bob...I've got exactly the same specs as you...STi valves (not oversized though), compression, porting, stand alone ECU. Interestingly I only got 165hp. To this day I've been confused by that, as mathematically, we should have been up where you were. Mine also overheated, but I initially have put that down to airflow through the engine bay due to the sump guard potentially blocking off the air. Perhaps that's not true...might need to spend some mroe time looking at that. I'm interested to know about your static timing. Did you set it up using the factory positions? Given the grinding of your heads, you'd realise, like we did, that the timing on the right hand head becomes more critical due to it changing as the belt goes longer. Can you share any of the static timing events? ie, Inlet 0.050" open and closed at what crank degrees? Ditto the exhaust? Thanks, Matt |
#150
What are you using for fuel injectors? Intake? Exhaust? Transmission
Bob, are you tuned using race fuel? Also Bob is using a 5 speed, which has a lot less drive train loss. The stock injectors get maxed out right away.
