Old 07-06-2001, 05:56 PM
SVXtypeR
All fluids are Redline (5w-30 for engine oil) and Militec (additive)
Old 07-06-2001, 08:32 PM
zsvx
synthetics
I'm suprised to see so many people running synthetic oil. How many of you guys started using synthetic oil at real high mileages (90K+ miles)? I always hear stories of people leaking oil big time after switching to synthetic in high mileage engines.
Also, I thought the owners manual said not to use 5W-30 oil for "sustained high speed driving". What does that mean exactly? I don't plan on running the Indy 500 in the SVX anytime soon
Old 07-06-2001, 08:40 PM
KEVINL
My SVX has had Mobil 1 since 120K miles only had to replace valve cover gaskets no engine oil leaks anymore at all
Old 07-06-2001, 10:43 PM
kvnobrien
I had all the seals replaced, andi've been using mobil for 40k. Seals were replaced after an overheat tho. Randy - I've seen the chart(i have 2 manuals!). I was just curious.
Old 07-07-2001, 08:54 AM
immortal_suby's Avatar
Thread Killah
I use the same synthetic in my car and the wife's car. I switched mine when I bought it at 100k. It already leaked from the front main seal at that time, but after replacing that I have nothing but a very minor valve cover gasket leak. We bought hers at 100k also and I have yet to see a drip after switching it to synthetic.
Locker Link
2015 BRZ Limited 6MT
Old 07-07-2001, 04:18 PM
joeaux
Castrol SynTec. Good stuff. Been in mine since day one.
-joe-
Old 07-08-2001, 08:28 AM
svxxx26's Avatar
svxxx26 svxxx26 is offline
Headed to Texas...
Mobil 1 15W50. Started using it at 25,000 miles - no leaks.
Use Red Line synthetics in the front and rear diffs and the ATF.
Jerry
2005 Baja Turbo
2008 Ford Crown Victoria Police Interceptor
jnj7707@yahoo.com
Old 07-08-2001, 10:55 PM
zsvx
I assume you guys also haven't noticed your engine burning any oil in addition to the (no) leaks.
Old 07-08-2001, 11:10 PM
KEVINL
my engine uses not a drop of oil not bad for 130K miles
Old 07-08-2001, 11:31 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Unfortunately, mine is beginning to use a bit of oil, even with no leaks. But, what can you expect from a car with almost 160K.
Randy Johnson
Mike Davis -- at Reading VI
Old 07-09-2001, 08:11 AM
svxxx26's Avatar
Headed to Texas...
I haven't noticed any oil consumption at all.
Jerry
2005 Baja Turbo
jnj7707@yahoo.com
Old 07-26-2001, 02:35 PM
kvnobrien
bump
Old 07-30-2001, 09:18 AM
nvrmore100's Avatar
nvrmore100 nvrmore100 is offline
This account is scheduled to be deleted for inactivity
Send a message via AIM to nvrmore100 Send a message via Yahoo to nvrmore100
Ok here is a dumb oil question. I took my car to a quick lube place (yes I usually do it myself, but I was taking the car to Canada the next day, and was WAY too busy!). Anyways, I brought in my Mobil 1 5w30, and got them to put it in for me. The guy at the quick lube place got all in a huff, trying to explain to me that my car REQUIRED 10w30 oil and not 5w30.
This totally confused the heck out of me. He was ADAMANT that this was case and I would doing SEVERE damage to my car by using it. I basically told him he was on crack and that he will put it in or I will simply take my business elsewhere.
Now here is the question. I'm no rocket scientist, however I do understand what the weights mean. 5w30 is a 5 weight cold and 30 weight hot oil. He was going on about how my car will overheat and it will be too slick when the engine heats up. Now can someone tell me that I'm totally wrong in saying a 10w30 is the same darn hot weight oil as a 5w30??!?!?
In fact I would assume I'm doing the engine a favor on startup simply because the oil is less viscous at cold temperatures than a 10w30 is. Hell in the winter in Canada I would use a 0w30. After watching the oil videos with the clear engine in mech class, I really want a pre-luber!
Anyways, my rant for the morning.
Ryan
92 LS-L Claret / Black UR Underdrive Pulley, Bosche Platinum +4 Plugs, K&N Cone Filter
http://www.ryanmacdonald.com
http://www.digitalvertigo.net
http://www.open-innovations.com
Old 07-30-2001, 11:54 AM
lightning_8669
Citgo 10-30
Old 07-30-2001, 02:07 PM
Ron Mummert Ron Mummert is offline
Invisible avatar
Send a message via AIM to Ron Mummert Send a message via Yahoo to Ron Mummert
Wink
I would TEND to agree with the 5w part as, "what difference does it make in the summertime, anyway?" However there's always an engineer around who will dispute our layman's theories. I just put 5w30 in mine, simply because the discount club was out of 10w30. If my car blows up I'll post this little inconvenience to all. Ron
Ryan
Good s**t happened. 69 was worth the wait.
'92 stock semi-pristine ebony - 160K
'96 Grand Caravan - 240K
'01 Miata SE - 79K
'07 Chrysler Pacifica - 60k - future money pit.
