Old 01-11-2018, 01:47 PM
elemgee elemgee is offline
Tachometer RPM's Reading Low
My 94's tachometer recently started reading low RPM's. At idle, for instance, it reads around 300 rpms. When accelerating, the highest it will read is around 1,400 rpms. The engine runs and sounds fine.
Thought it might be due to the very cold weather we're having here in the northeast but its around 60 degrees today and the problem persists,
Any ideas?
Thanks.
Larry
Old 01-11-2018, 02:45 PM
oab_au oab_au is offline
Re: Tachometer RPM's Reading Low
Any ideas?
Thanks.
Larry
Hi Larry, the taco gets it's signal off the ECU, so does all the other units, engine, gearbox, etc, so that should be OK.
It does have a separate ground up behind the dash, or it is seizing up.
One Arm Bloke.
Tell it like it is!
Old 01-12-2018, 06:44 AM
gwynethh's Avatar
gwynethh gwynethh is offline
Mine is doing the same a bit intermittently. I have a replacement unit ready for install during car work season (July1 to Aug 30 here in New England). Here is a proof of issue video. https://www.youtube.com/watch?v=JMQ1apL_uC4. Keep us informed of your solution.
"Peace is the flower of justice."
Old 02-01-2018, 07:10 AM
Levoi Levoi is offline
Yes I have the same issue, and also the speedometer is off (to low). 1 speeding ticket as a result so far..
Idle is a very convenient 0 RPM according to the tachometer...I have the idea that this does become somewhat better when driving for a long distance, so bad voltage / ground may be to blame? I don't see how the engine could run fine with a bad ECU, but honestly i'm don't really have a lot of knowledge in that department.
Please keep us posted!
Old 12-23-2021, 12:18 AM
Anyone resolve this issue? I'm having the same symptoms and thinking its something in the cluster.
Old 03-03-2024, 04:10 AM
calisvx calisvx is offline
*bump* anyone ever resolve issue Sam having the exact same thing and I have no idea as its intermittent =(
Old 03-03-2024, 07:47 AM
Noriyasu Noriyasu is offline
This is probably a capacitor issue. The life of the electrolytic capacitor on the printed circuit board of the tachometer is about 4000-8000 hours.
I saw a similar topic on this forum recently.
Old 03-03-2024, 03:08 PM
Mine turned out to be a capacitor issue. I swapped the tach out for another unit that works.
I ran into a similar behavior with my speedometer, and it was capacitors leaking, too. A friend soldered in new ones for me and my speedometer is working well again. I will probably have them repair my original tach eventually.
Old 03-04-2024, 03:53 PM
Thanks everyone for the info! I will source the parts and solder new ones =) i was going crazy check all the electrical and not finding any problems =( i will update once complete in a few weeks.
Old 03-04-2024, 06:06 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
https://youtu.be/ujYNeFCSng4?si=frFoXyTospCMeR_2
I followed this one and fixed my tach.
Here's a couple more with the speedo too. Mine needs the speedo done.
https://youtu.be/nycVuO1O5KY?si=-Nd39EBSR7-SvGSd
https://youtu.be/lpz2lJUfCek?si=1LMCRe3hngjnvIWG
'20 Honda Ridgeline
http://www.x35design.com
Old 03-04-2024, 07:07 PM
It may be worth mentioning, though unrelated to the OP: I forgot to mention that I ran into bad capacitors in my climate control unit, too. Also had a friend help me repair that.
Old 03-04-2024, 07:50 PM
I had same experience in climate control unit.
It is well known that the 4WS controller has the most capacitor problems. I think it's because it's located in the trunk and gets hot.
Old 03-05-2024, 12:51 PM
Oof. I am not looking forward to that one. I was promised a spare when I bought this car, but that never happened. I have been keeping an eye on yahoo auctions.
Were you able to repair your 4ws computer?
Old 03-05-2024, 08:56 PM
I have no experience in 4WS because my Car has no 4WS. But, following website will be useful for you.
https://minkara.carview.co.jp/userid...8228/note.aspx
I'm an electrical engineer, so replacing these parts is easy, but if you're not confident, ask someone who is good at soldering to do it for you. It's basically the same job as replacing a meter's capacitor. However, the PCB pattern may be corroded due to capacitor leakage, in which case repair may be necessary.
