Old 11-01-2017, 01:23 AM
Sleeve Lock Regulator Replacement with PHOTOS
http://www.subaru-svx.net/forum/atta...1&d=1509520964
Old 11-01-2017, 07:10 AM
SoCoNoHa's Avatar
SoCoNoHa SoCoNoHa is offline
H6 Fanatic
Re: Sleeve Lock Regulator Replacement with PHOTOS
Well, SOMEONE gets up early...
Thanks Svxcess, now that I know where It goes, I'll check the ones in my doors. One of those was in the glovebox when I bought my SVX, but my windows seem to work fine so I never looked into it.
1992 SVX LS-L : King of the Stable
LGT 5MT, ABS Delete, Short Ram Intake, Custom Exhaust, Drilled/Slotted Rotors
1993 Legacy sedan : winter beater, supposedly.
1994 Legacy wagon : future drift car?
1995 Impreza coupe : EZ30++, daily racecar.
1997 Legacy GT : date night rocket?
2003 WRX : future winter beater
Old 11-01-2017, 12:39 PM
gwynethh's Avatar
gwynethh gwynethh is offline
Thank you very much. It is only a matter of time before most of us will nee d this info.
"Peace is the flower of justice."
Old 11-02-2017, 04:48 AM
theflystyle's Avatar
This part shows up as no longer available (NLA) on most sites. Its a perfect candidate for 3D printing - small and made out of plastic.
As soon as my baby gets a little older, I want to dive into creating parts for the SVX on a printer and making them available for download for free. Hopefully by then there will be more viable and cheaper options for 3D scanners.
1994 SVX LSi
2008 Legacy 3.0R
Old 11-03-2017, 01:05 AM
svxnavyvet svxnavyvet is offline
I have a 3d printer and a kid that can auto cad anything will look into this.
Old 11-04-2017, 11:54 AM
That would be fantastic. As long as the material is a strong as the nylon original part to handle whatever stresses there are.
This is a part that could take many SVX's off the road if it could not be replaced. Every sale that needed a safety inspection to be registered would fail if the primary windows did not operate.
Old 03-24-2019, 03:39 PM
Exclamation Re: Sleeve Lock Regulator Replacement SOURCE
UPDATE
Just to let you know, the sleeve lock regulator used on the rear windows is the identical one to the front. Though used, the yprobably are stronger, since the rear windows get far less usage over time and the strain on the regulator is far less since the window is smaller and lighter in weight. As long as you're going to a pick n' pull, might check this location for spares.
File Type: jpg 54727421_270380177221320_7292289323926290432_n.jpg (23.6 KB, 2037 views)
Old 03-24-2019, 06:54 PM
Good info. One more thing to remove from my parts car before it goes to the scrap yard this summer.
Old 03-25-2019, 02:49 PM
irox irox is offline
If anybody has a broken or damaged one (or a good one), I would be up for modeling it and printing it to see if this would work. Once we have the model, we can order from online services which can printer them in strong materials than we generally have access to as home/hobby makers.
Alternatively, if somebody wanted to measure the heck out of and send me the measurements, I could try and model/print one that way.
Cheers,
Ian
Old 04-26-2019, 08:34 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
I just replaced mine. Unfortunately, that wasn't the problem so, I now have a dirty but unbroken one available for loan.
Gene
Gene and Ben
Old 09-23-2019, 12:15 PM
jes's Avatar
jes jes is offline
(continuing from "What have you done to your SVX...")
If there is a batch made, I'm in for a few...
I found a local 3D scanning company, but don't want to take apart a working window unless I have to. I also noticed the UPS store lists 3D printing (no scanning) service at some locations.
Old 09-23-2019, 12:56 PM
jes's Avatar
jes jes is offline
Lightbulb part number...
probably should add the NLA part # so this thread shows up in searches...
Sleeve Lock Regulator - 62101PA081
Old 09-23-2019, 04:36 PM
If somebody has a clip for loan, please PM me and I'll give you my address (I will return after creating the model). (Sorry bwb3, I didn't see you reply, if the offer still stands let me know.)
Otherwise, if somebody could post pics of the clip with some measurements (widths, thicknesses, lengths, heights, etc.), I can try to model it that way.
Or I could try with a broken clip if anybody has one to spare.
Thanks!
Ian.
Old 09-24-2019, 08:31 AM
bwb3's Avatar
I PM'd you Ian.
Gene
Gene and Ben
Old 10-07-2019, 11:43 PM
A big thanks to Gene for the loan of his spare clip! Thanks!
Took the first pass at creating the replacement sleeve locker clip. All the key dimension are with in 0.1mm between the original and the copy. Note, the copy does look slightly larger in the picture, but this is because it has square corners, and the original has more rounded corners/edges making it appear slightly smaller.
Also, a week ago my passenger side window stopped working, and the motor just runs. I've not taken a look yet, but it might be an opportunity to test out the 3d printed Sleeve lock clip.
Next steps in development:
- Make sure the clip fits in a real window assembly.
- Try to identify places to add reinforcements to the clip.
- Publish model and code on thingiverse.com.
Ideally, I should take an old SVX door, hook it up an Ardunio with relay shield, and make it drive the window up and down all day counting the number of operations before the clip breaks. But I don't have a spare door, or space to set that up.
The clip should probably be printed in Nylon, so I will try to get a price from shapeways.com (and order one if it's not crazy expensive).
Another possible approach to getting a durable clip could be casting it in nylon resin, or something. Using the model I could create a two piece mold which could be 3D printed, this could be used to cast the final clip.
Cheers,
Ian.
