Old 07-20-2016, 09:55 PM
ManYaik ManYaik is offline
FS:AZ: '04 STi 6 Speed Transmission + R180 rear diff **PRICE REDUCED**
***SOLD***
Howdy Subaru Peoples!
Up for sale is a 6 speed transmission (Tranny code: TY856WH4MA) from a USDM 2004 WRX STi with 30k miles on it(That's what I was told anyway). I no longer have a car to use it, so it is now for sale. All that comes with it is:
6 Speed Transmission (needs DCCD wiring harness. can be ordered from Subaru dealer for $50, Also needs input shaft seal replaced but I have one and will be included)
Tranny mount and crossmember
Shifter
Input shaft seal
Clutch master cylinder and slave cylinder with tubes and hoses
R180 rear differential with dogbone rear mount
2 rear axles (one of the outer cv boots need to be replaced on one, and the threads(where the axle nut goes on) is buggered up a bit on the other one )
Flywheel, but no clutch (the friction disk got oil on it from the leaking input shaft seal)
Left and right axle seals for front diff
Plug for access point for shift fork pin
New stud for rear diff (one is chewed up pretty bad)
Stub shafts for front diff (These can be used to attach female front axles. This can be useful for swapping into '93-01 Imprezas, '90-04 Legacys and SVXi )
Pedal box (just brake and clutch, doesn't come with an accelerator pedal)
Starter motor
Brake master cylinder and booster
Thanks for looking!
'95 SVX L AWD 99k(R.I.P )
4.44s
Bontrager Works RSB
ECUTune V1.4
Custom Cat-back
Old 10-31-2016, 07:15 PM
Re: FS:AZ: '04 STi 6 Speed Transmission + R180 rear diff + other parts
BUMP still for sale
4.44s
Bontrager Works RSB
ECUTune V1.4
Custom Cat-back
Old 11-04-2016, 04:00 PM
BUMP Price Reduced
4.44s
Bontrager Works RSB
ECUTune V1.4
Custom Cat-back
Old 11-04-2016, 05:47 PM
DallasSVX92's Avatar
DallasSVX92 DallasSVX92 is offline
So in Layman's terms, what all else would be needed for a swap into my 92 SVX other than what you have listed?
Old 11-04-2016, 07:04 PM
A clutch, longer flywheel bolts, and a custom crossmember
4.44s
Bontrager Works RSB
ECUTune V1.4
Custom Cat-back
Old 11-19-2016, 09:06 PM
***sold***
4.44s
Bontrager Works RSB
ECUTune V1.4
Custom Cat-back
