question about rear vented rotors
I was reading some old threads concerning brake upgrades and discovered that the SVX's in the UK/NZ and maybe other markets came w/ vented rear rotors. Has anyone made a swap of these vented rear rotors into our USDM SVX's ? The ticker rotors would require wider calipers and maybe a different proportioning meter but would certainly help braking fade. Since our calipers are from the Legacy, a swap would seem possible.
Re: question about rear vented rotors
i put the rear vented/slotted rotors from disc brake Australia on mine. was not worth the time/effort involved. it took three attempts and six months to get the right parts and it wasn't a noticeable difference. the front brakes are the weakest point on the svx, the rears seem adequate.
Kind of sorry to hear that it's not a simple swap. Since it is OEM in some markets, I thought it might just be a matter of wider calipers and different brackets.
European SVX owner here: those vented rotors are PITA to get. I actually wonder if going US-spec rear brakes wouldn't be a better option...
Slotted / vented / cross drilled etc, are cheap enough on Ebay..
http://www.ebay.ca/itm/FULL-KIT-BLAC...BXpXfn&vxp=mtr No, they're not Brembo.. but they'll work just fine for anything up to aggressive street driving. I've gotten on mine HARD from over 200 KPH, .. they didn't warp :-) Neither did the fronts, same kind. That being said, I don't think that they'd hold up to Autocross type driving, but for agressive street driving, they're fine, and I love the sound.. |
U mean these
I had a caliper seize up so bad I had smoke coming out the wheel well when I parked .. Rotor is fine.
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. |
NZ new did not come with vented rears - but there are quite a few JDM imports here with vented rears.
If you (in the USA) decide to "upgrade" to vented ones then you will also need different calipers and pads - which you will find hard to get hold of in the future.... Check out this site which I have used to get a few parts from in Japan - quite a bit cheaper than local in NZ. http://www.jauce.com/search/Subaru+SVX have fun.....
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
Since our calipers are from the Legacy, I thought that getting rear vented rotors/calipers/brackets wouldn't be such an issue.
I also remember someone mentioning that they are the same as Nissan Pathfinder ?.
The Pads are according to the x-ref materials.
Are we saying that the rotors/caliper are from the Pathfinder since the pads are from that vehicle? Many cars/crossovers/etc. can use the same pads but the remaining brake parts are different.
