Vibration
I have had a vibration in the car for quite some time. I originally thought it was the front axles. I replaced both of them when a boot cracked open. The vibrations seemed to get a little better but didn't go away completely. Yesterday I noticed something that clearly was not my imagination. I got onto a highway and, while accelerating, it was vibrating quite a bit. Then, suddenly, it got way better. It seemed to happen when I backed off on the accelerator but subsequent attempts to hit the gas did not bring back the vibration. I was feeling it both in the steering wheel and the whole car. When it got better, there was just a slight vibration in the car, or so it seemed.
Any ideas? Car still idles pretty good and gas mileage on the highway at 70mph was about 27. Seems like it is running well. U-joint maybe? Steering rack issue? I do get some burning smell that snells like burning ATF but no major spots on the driveway.
Re: Vibration
As far as the burning smell, does your power steering have a leak? That is usually what it is.
Re: Vibration
Hi Tony,
The driveshaft bearing can make a vibration. I'm not sure how to test it though.
Cheers! Gordon 1997 Ebony #308 113k "The Black Diva"SOLD 1992 Black over Liquid Silver 152k SOLD 1992 Ebony 251k 444 SOLD 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
Re: Vibration
Where is that located?
Re: Vibration
There is one in the center. It looks like a standard U joint, but staked in. It is considered not replacable. YT tried replacing one for me, but had trouble. My local driveshaft shop (Connecticut Driveshaft) who does all sorts of trick driveshafts for racers, etc. said it was better to buy a replacement driveshaft...
Re: Vibration
are replacement driveshafts even available for our rarer than rare cars?
go ahead and have that place look it up for us.
1985 Brat GL 138k 91 CRX Si 40k 91 CRX Si 155k 97 SVX Lsi 70k 2003 s2000 91 RT4WD 166K |
Re: Vibration
Is this referral to "Prop-shaft bearing" indicating what in my FSM is called the "Center bearing", and subject to availability problem? The FSM says the "Center bearing" is replaceable. Sounds like she has one available.
http://www.subaru-svx.net/forum/showthread.php?t=63711 Glenn
