Re: Hood struts: FYI
Or gee just new hood struts.
4138T57 Gas Spring with Ball-Joint End Fitting, 90 lb Force, 19.72" Extended Length, 7.87" Stroke 2 Each Enjoy!!! P.S. I forgot to tell you that I did have to "drill" out the rivets in the brackets first, but still, it was no trouble at all. Be sure to keep all the original spacers ... With those, the threaded ends fit perfectly. Good Luck! Rico
~I hear and I forget, I see and I remember. I do and I understand~ 1994 Subaru SVX LS_Color: "Infinity/Emerald Mist" My Other Ride is a Sailboat: San Juan 7.7M Formerly owned 3 Subie XT's |
1992 Pearl LS-L : Trans-cooler / ecuTUNE Stage 1 Chip / Pioneer AVIC-U310BT Navigation I hear what you're sayin', but whatta ya mean?! |
So when done it will only cover the extended portion of the cylinder. I could make a shorter one if I want the hood only 1/2 up. That's what I do at car shows.
Just to confirm....McMaster-Carr part, right? EDIT: I see the part now. Per your prior post, do you think 60lbs would get the job done?
THX Last edited by fasteract7; 08-07-2014 at 04:34 PM. |
Drilling out the rivet of the OEM bracket and using the original spacers (with photos) can be found HERE.
This is by far the easiest way to replace the hood struts and is what I am currently using on the polo. Craig, I think 60 lbs. is too light to raise the hood easily and hold it securely. .
I'll second that 90# choice.
Since I'm here: Nate, all those ball studs I gave you are for the hood strut custom replacement documented elsewhere in the forum.
Great info, I ordered mine today!
-Nate '92 LS-L Pearlie |
I ordered mine yesterday! These are much cheaper than the SPD hardware ones. Hopefully quality and durability are as good as price
Sam Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners My Locker |
Perhaps I am missing something or it isn't quite as intuitative, but the link posted by John instructs to "drill" out the rivet which holds the nylon bushing together. How exactly is the rivet drilled out?
The rivet will actually break apart and you can push it out. Then you will see the plastic bushing in the hole in the bracket. I have even done it by hand, holding the bracket in one hand and slowly drilling into the indent with the other. This is a soft rivet so you don't need a lot of speed, just a sharp bit. Just a note: your plastic bushing will be black. I painted mine gray for clarity of the photos) .
#28
Got it! I'm a fan. One of the easiest fixes yet.
#29
The mcmaster part numbers all show a 5/16"-18. Which isnt an issue on the frame/body mount as I can swap to a 5/16" nut, but the hood mount mount is tapped metric. I am trying to avoid a re-tap on the hood mount holes, to 5/16, and would consider just ordering a new set given the relative affordability.Which end would be the "right ends"?Ballsocket?eyelet?threaded?
Adam 96 Ebony Pearl LSi - 116,XXXK 02 Avalon XLE Gold - 160K - SOLD 08 Tribeca - 85K - SOLD 13 Explorer - 70K - SOLD 13 JD z425 Zero Turn 15 CubCadet XT1 19 F-150 - 30K 19 Volvo XC90 T6 Momentum |
#30
W
U T about trunk STRUTS?
1985 Brat GL 138k 91 CRX Si 40k 91 CRX Si 155k 97 SVX Lsi 70k 2003 s2000 91 RT4WD 166K |
