Old 05-06-2006, 12:08 PM
I just posted it into the How-To Documents. Thanks for the write up Tom.
Old 05-06-2006, 09:24 PM
very cool, thanks Earl
Old 05-06-2006, 10:11 PM
Nemesis Destiny's Avatar
Nemesis Destiny Nemesis Destiny is offline
6MT STi-ified, now with R180!
Send a message via ICQ to Nemesis Destiny Send a message via MSN to Nemesis Destiny
Not to sound like an idiot (though sometimes I am), I can't seem to find this writeup. Can one of you point me in the right direction, please?
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto.
1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong!
2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver.
1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver!
2007 Honda CR-V, some awful shade of light green *yawn*
1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED.
1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust*
Old 05-06-2006, 10:39 PM
I will post it now. I had computer problems before and could not put it in the How-To Docs. I will do it asap and try to post the link.
Old 05-06-2006, 10:50 PM
Heh, no worries, at least now I know I'm not crazy or a total retard.
Old 05-08-2006, 12:27 AM
Well, you may be that, but here is the link to the file.
Old 05-08-2006, 04:49 PM
Awesome writeup! I know this will come in handy. Thanks.
Old 10-15-2007, 06:08 PM
/Subscribe because I'll need this as a reference very soon.
Anyone reading know anything about "tranny codes"? I guess so we can verify the tranny we are looking at is a WRX 5mt. My friend shipping it I guess is trying to make sure I "don't get ripped off".
Old 10-15-2007, 06:09 PM
just look at the clutch fork. If it sits on a pivot ball, its not a wrx trans, if it rides on a 1/2" shaft, then its a wrx transmission
Old 10-15-2007, 09:39 PM
Hondasucks's Avatar
Subaru Technician
Don't ALL the turbo trannies ride on a 1/2" shaft?
Good write-up, Tom... I can't wait to get mine 5MT swapped :-)
1986 VW Jetta
Old 04-08-2014, 01:25 PM
jcimos's Avatar
jcimos jcimos is offline
Re: 5mt writeup... Finally done
Hey guys, I know its taboo to piggy back on someone else thread, but I really need some help. If you have a Legacy 5mt complete swap and you want to go to a WRX swap, what do you need to replace in the Legacy swap? And when i said Legacy complete swap I mean including the rear 4.44 LSD rear diff.
ALL WAYS JUDO CHOPIN'
"Wait...your grill...is that chicken wire?"
Old 04-08-2014, 08:42 PM
Subachouli Subachouli is offline
Subaru Parts Guy
Which 5MT Legacy transmission uses a 4.44 fd? US Legacys had 4.11. Is it a turbo GTB transmission from overseas?
If it's a turbo transmission than you're using a hydraulic pull clutch, which is the same set up as the 02-05 WRX transmission. 06+ went to push style slave cylinder.
If it's a US Legacy non turbo transmission, it's a push style (same as 06+ WRX). I think you'll need to change out the clutch. Definitely the slave and fork.. I think.
You'll need to match the transmission final drive to the rear end. You may need the axles from the WRX. You can reuse your pedals (assuming you're going from hydraulic to hydraulic), driveshaft should be the same, mounts are the same. Shifter should be the same but if it's different you should be able to make something work.
What else..
Dunno if this is what you're looking for. You can PM me if you have questions. And stick around, someone should chime in with more knowledge.
1994 SVX- 5MT, Deltaspeed, Stebro,Work VSXX
1994 Legacy GT
2001 Forester
2002 Impreza WRX
2005 Impreza WRX STI
Need parts?
Old 04-09-2014, 12:14 AM
jcimos's Avatar
Thanks for replying on the thread. All i know about the setup that i have is the tranny is from a late 90's n/a Legacy and it cable driven. The drive-line has been adjusted and the internals of the rear end has a Legacy components in it. I believe its the 4.44 lsd Legacy swap. The new tranny i have is from a 03 WRX turbo model. My pedals was setup for cable. The clutch and flywheel I have in the car now is from a n/a Legacy. I just want to know what i need to do to install the WRX tranny in replacement of the Legacy. Thanks
Old 04-09-2014, 10:16 AM
Subaru Parts Guy
Got your PM, but I'll keep the info in the thread so it can be looked over and used in the future.
You'll need everything but the modified transmission crossmember and the modified driveshaft. You might be able to get away with using pieces from both shifters.
The 90's Legacy transmission is a push, cable clutch style. The 03 WRX is pull, hydraulic.
So your pedal box needs to be modified to use a hydraulic clutch. You'll need the actual hydraulic components, master, slave, lines, hose and a spot on the firewall to mount everything.
You'll need a new clutch and flywheel to match the transmission.
I believe you can use the factory SVX rear diff with a 03 WRX transmission. The 90 Legacy NA transmission is either 3.90 or 4.11 FD, so the 4.44 rear diff won't work.
I'm sure I'm missing something.. anyone else?
1994 Legacy GT
2001 Forester
2002 Impreza WRX
Need parts?
Old 04-09-2014, 01:50 PM
Tireiron Tireiron is offline
My big question is, you already have a 5mt that is setup correctly and working, why do you want to swap to a different 5mt? The WRX 5mt is no stronger than the legacy 5mt. You will not get a better final drive as the WRX final is 3.9 and the legacy is most likely 4.1. Also if the legacy 5mt breaks they are still easier to find in good condition than WRX ones.
So again, why exactly do you want to swap from one 5mt to another 5mt?
