#556
Re: Building a 10,000 rpm NA engine.
Well we have some progress, after years of trying to sort out the individual throttles I have stepped back and purchased a set of BMW M3. Go to say they look great, also have the advantage that the ID is 50mm as opposed to the SVX injector manifold of 44mm. So I have made up the first adapter plate but I want to try a different design so the injector is at a better angle in relation to the back of the valves.
Also as this engine is for the mid engine project, I plan to do the throttle by electric. I purchased the gas peddle from a M3 and the throttle actuator, in addition got a controller that should run all the smarts between the two and make it work. The photo is of the first draft of the mounting plate. What I will do is once its finished if any one wants to make one I can supply the dxf. Harvey you will have to change the intake on you computer simulation. Ram pipe options are 50mm, 100mm, 150mm & 220mm so we need to figure out which is best. Keep well all. Tony
#557
Sandals in the machine shop! Watch those toes, Tony!
Cheers, Bill
#558
On a Volks forum a gentleman is considering putting these Ducati ITBs on an EG33. Not sure if its relevant to this motor. No idea if they were ever actually made to work either. But they do look cool.
Not really designed for low rpm operation, 6000rpm up.
#560
They are very nice looking units. Any idea what size in Litre the bike engine was?
Tony
#561
Ducati 999cc. 90* V-Twin, max power at 9750 rpm, desmodronic valvetrain.
cheers -Evan |
#562
Evan,
Do you have a link to the VW web site? Also was reading a bit on a ECU forum this morning and they suggested that a turbo engine by default has more oxygen in the chamber and there for has a better burn as a result. This leads me to the question why does higher compression give more power???? Anyone know. Tony
#563
Higher compression gives increased cylinder pressure, which results in more force pushing the piston back down on combustion.
Forced induction also increases cylinder pressure resulting in more force pushing the piston down on combustion. However with forced induction there is an increased quantity of air so there has to be more fuel to compensate giving even more force on the piston after combustion. |
#564
Accept the turbo point,
but not the NA, it takes more energy to compress the cylinder so not sure you suddenly get more back just from that point. I maybe wrong but I think there is more to it. Tony
#565
Think of it as more bang for your buck. You're compressing the air in the mixture more, so you get a more powerful explosion from the air-fuel mixture. The increase in the force generated by the more powerful explosion far outweighs the addition energy needed to compress the mixture. Note: You do need to be mindful of not getting to the spontaneous combustion pressure! Cheers, Bill
#566
Thanks Bill, got to wonder if its also a better explosion as well.
Here is the design for the adapter plate to fit the BMW throttle so they can shoot the fuel direct to the back of the valves. Tony https://dl.dropboxusercontent.com/u/...20Assembly.pdf
#567
Tony,
It is indeed a better explosion! It is a much more efficient use of the fuel within the air-fuel mixture. So, are you going to drop the drawing specs into your work cell and let the mill go after a hunk of 6061? Bill Quote:
Retired NASA Rocket Scientist Most famous NASA "Child" - OSIRIS-REx delivered samples from asteroid BENNU to Earth in Sept. 2023 Center Network Member #989 '92 Fully caged, 5 speed, waiting for its fully built EG33 '92 "Test Mule", 4:44 Auto, JDM 4:44 Rear Diff with Mech LSD, Tuned headers, Full one-off suspension '92(?) Laguna, 6 spd and other stuff (still at OT's place) My Locker Last edited by SVXRide; 04-16-2013 at 07:04 PM. |
#568
Bazza got set up with a electric motor and VSD to run some more coolant tests, aim being to get around air build up issue, VSD should run water pump up to 11,000 rpm and if we want we can go higher still. Part for gearbox on dyno arrives tomorrow, computers is set, we need to mod the frame and drive. Controller to run throttles by wire should be here next week so it all seems to be coming together. Tony
#569
Excellent!!
Cheers, Bill Quote:
