Porsche resonance intake
Check out the latest issue, from page 28 on. Looks partly familiar :-)
http://www.porscheengineering.com/pe...tomermagazine/ / T |
Re: Porsche resonance intake
"a new, more compact two-stage intake manifold. The last comprised twin resonance chambers or tracts -- one long, one short -- feeding air to the intake pipes via a Y-shaped passage from the throttle body. Below 3,500 rpm the engine breathed only through the long tract; above that, depending on throttle position, a butterfly valve in the second tract opened to increase airflow. Porsche claimed this setup ensured at least 300 pounds/feet of torque from 2,700 to 4,750 rpm, a “fat” torque curve, indeed." http://auto-howstuffworks.bestgle.co....htm/printable
Alan 1987 928 S4 (Black) SOLD! 1997 SVX LSi (Ebony) SOLD! 2005 Legacy GT (Silver) [Cobb Stg 2+] SOLD! 1987 928 S4 (Black) SOLD! 2005 Forester XT Premium (Crystal Gray Metallic) SOLD! 2008 Lancer Evolution X MR (Apex Silver) [Cobb Stg 1+] 2015 Outlander Sport 2.4GT AWD (Mercury Gray) 2013 G37xS (Obsidian Black) |
Yes, but on this one there's one more feature included
/T |
Looks like Porsche has decided use the Helmholtz chamber theory that the SVX has had, to increase the torque at the 3000+ rpm area. This is mainly adaptable to 3, 6, and 12 cylinder engines.
It looks like they use a different tract for the high end resonance, by the flaps that change the inlet tracts from the inertia system tracts, to the different length resonance tracts. The SVX uses the same inlet tracts for both the inertia, and the resonance system, as it has a lower peak torque rpm. Nothings new is it??????????? Harvey.
So ........ how is this different from when Porsche did it before on the 928?
720/4 equals 180* and thats not enough inlet duration for an engine. The 8 cylinder used two different length inertia tracts, that it switches between. Not the pumping action of the SVX inertia system. Harvey.
