Exhaust-like smell coming through heater vents
I seem to have a rather unpleasant smell coming through the heater vents that almost smells like exhaust. It doesn't really smell like burning fluid (neither oil nor ATF). Has anyone here experienced this and determined the cause? I don't hear any exhaust issues other than the resonator which buzzes a bit
Thanks |
Re: Exhaust-like smell coming through heater vents
If it is sweet smelling it could be the heater core leaking or a hose. Get a battery powered home CO alarm and put it on the front seat. That will tell you if it is exhaust or not
If it is the heater core leaking, your windshield will fog over if you turn on the defrost before the engine heats up.
That's a good idea! I'll try it and post back.
Power steering leaks have been a persistent PITA for me and that smell comes in through the vents. If you see drips under the car, put paper towels under there and look at the color of what drips.
There may be a slight ATF drip from the PS pump, but it sure smells like exhaust.
Exhaust flowing into the coolant may be the sign of a heat gasket issue.
If you smell the coolant reservoir under the hood, does it smell of exhaust? How many miles on the engine? A quick test to see if your getting combustion gasses in your coolant via a head gasket: Smell the coolant. If its bubbling into the overflow tank, give it a sniff as well as when its cold pop the cap on the radiator and do the same. If it smells like exhaust or gasoline, then regretfully you have a bad head gasket. This will lead to your radiator blowing all of its coolant into the overflow tank in a short time, like a few days. Pop the cap when your car is cold and see if the radiator is loosing a lot of coolant. Its a tell-tale sign. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 01-22-2013 at 06:33 AM. |
