#196
Re: Building a 10,000 rpm NA engine.
Also we had some stock cams profiled at Tighe last week - they're different to the above published "stock" specs. I'm a little worried if we rely on these figures we will end up down the wrong path. Last edited by bazza; 08-05-2012 at 11:22 PM. |
#197
Congratulations Bill.
Now you will have the time, to put it on the dyno. Harvey.
#198
Harvey, Thanks! YT made getting the car to a dyno soon a condition of his installing the Hydra Just need to modify the fg hood to clear the new intake. Bill
#199
All these results give us information that tell us a lot. Dan's first had low torque but higher rpms, the second had high torque but low rpms. which was the most drivable? Matt's first had every thing but rpms, the second had nothing but rpms. Matt was the only one to actually check the timing that the cams had. We know that it had inlet timing of 20*/70*. The 20* opening was not needed, but the 70* closing was right on the money. If the opening was knocked back to say 10* or less, and the throttle bodies were used to raise the resonate peak, I am sure it would give a good wide torque curve at a higher rpm, to produce the HP. Quote:
#200
Bazza,
When Tony gets his 10,000rpm engine going, the 6 speed DCCD box will be useless. He'll want much closer ratios...heaps closer. Theoretical top speed in 6th gear would be 360kmh. In reality, he'll max out in 4th at best. Carrying an extra 2 ratios and 60kg of weight for nothing. i'm thinking he'll be wanting something like a 2.5 or 2.2:1 first gear and maybe stop at an underdriven 5th or 6th ( like 1.2) depending on what final drive he runs. I put together some ratios for my 5 speed that better matched my proposed (at the time) 8000rpm limit. They were: 2.67 1st 1.94 2nd 1.43 3rd 1.17 4th 1.00 5th Even with that, at 8000 rpm in 5th the top speed was 230kmh...never going to happen in a rally. |
#201
As for skipping gears whilst racing with a 6MT... that's crazy talk and you would go slower. Maybe take your car down to the drags and you'll see for yourself or go get a PS3 with GT5. Quote:
Now with Matt's he did a run with the stock manifolds / fancy cams then another run with the fancy manifolds / stock cams. If I understand correctly he did not get a chance to do a dyno run with the fancy cams / fancy manifolds and he did not get a chance to tune ecu tune to suit the nice setup. So again it's very risky to try and determine valve openings of all things when the car never showed it's full potential - I think with the right tune and everything sorted it would've taken off. Dan's made power to 5800 rpm... still a long way off 7000 rpm and it's very hard to form proper theories based on the driver report. I posted this in the other thread - very good info. I'd be far more inclined to use a camshaft recomendation from these guys rather than blindly guess what "might" work from the above results. I'm the type of person who needs to see proven results rather than guess. http://www.tighecams.com.au/helpful-hints.htm http://kelfordcams.com/applications.aspx Quote:
3.636 2.375 1.761 1.346 1.062 0.842 (MY02-05 STI DCCD) - My current ratios. 3.636 2.375 1.761 1.346 0.971 0.756 (MY04 STI USA DCCD - maybe same as MY06 STI AUS, can't recall. 3.636 2.235 1.521 1.137 0.891 0.707 (MY08 STi DCCD onwards) - My old ratios. Having driven all 3 whilst racing (and most of the available 5MT stock and PPG ratios) this is exactly why I swapped out the long ratio box and replaced it with the close ratio box. Last edited by bazza; 08-07-2012 at 07:35 PM. |
#202
Yep, the closest ratio is in the original 6 speeds...and for a 10,000rpm engine, even if it's only going to 8000 or 8500...none of them would be any good. The rev drop between changes, and the possible top speeds render them inappropriate for this engine.
Targa is somewhat different I agree...but he'll struggle to get out of 4th...why would you bother? M |
#203
I should add, your needs, with a lower revving turbo engine are different. You have torque...us NA folk don't!
M |
#204
We can get it to run to 10k, but it won't operate up there, for long. 10k is 25mt/sec, and we like to have 20mt/sec as the upper limit for constant operation, thats about 8k. The loads on the conrod, and piston are huge at that piston speed, for any sustained running. The cylinder head is the limiting factor, the ports are too flat, to the chamber, and the valves need to be around 39/40mm. If you could get 37mm it there, the valves would be almost touching. Thats why you don't see 75mm stroke engines at that rpm. A shorter stroke and bigger bore gives bigger valves, so 41mm is what is used. So as I said before, the gearing and the course will set the rpm that it operates at. What ever that is, but I guess that it will be between 4 and 8k Harvey.
#205
Hahaha yes I have torque but it's not really useful. The power delivery isn't ideal at the power figure I wish, it just falls flat on it's face and doesn't rev and use the gearing effectively. The new cams should solve this and allow it to rev to 7K - I'll let you know.
#206
I look at the torque line that runs across the graph, regardless of the numbers. That line is comparably between all the engines. That torque curve, is the same as the graph, that shows the engines breathing, it shows how much air is filing the cylinder. A dip in the wave means that the breathing has reduced at that rpm. I look at the rpm to see why it has reduced, run back over it to see why, and try to improve it. It shows where the breathing drops off, and why it does. It gives the clues to what has to be done to get that line as high, and as long as we can, at the rpm that the engine has to run. Quote:
Do you believe that they have tested these cam profiles on a EG33 with the independent inlet tracts, that we will use, to produce the torque that we need, at the rpm that we will use. I think not. We will determine, what valve timings and lift are needed to do the work that we need. We will then know what the duration will be, then we look for a cam the is close to that, if we can't find one we have it ground. Harvey.
#207
I think we'll just have to agree to disagree. Good luck.
#208
Bazza isn't related to Trevor, is he?
Bill
#209
Fair suck of the sauce bottle Bill.
I've met Barry in person...and he's keen to explore the potential of an EG33. I think we should welcome new folk with open arms. And for him to question Harvey isn't a sign of disrespect or "Trevorness" it's merely wanting to learn more and test ideas. After all, didn't some folk question the old guard who said the earth was flat? M |
#210
Fair enough I was just starting to get a little concerned that the tone of the conversation was going in a bad direction -- i.e. away from reaching the objectives stated way back in post #1 Civil discourse is always a good thing in my book! Let's get back to it! Bill
