Old 05-23-2012, 12:55 PM
Re: svx remote
Sorry it is dit , dit, dit, da ,da ,da ,dit, dit, dit
And dit , da da , dit is a call = CQ
Old 05-23-2012, 05:28 PM
oab_au oab_au is online now
Re: svx remote
And CQ means, "Seek You".
One Arm Bloke.
Tell it like it is!
Old 05-23-2012, 06:24 PM
Re: svx remote
http://freenet.msp.mn.us/people/calguire/morse.html
How did we end up with this I FORGOT
Old 05-23-2012, 08:25 PM
dromano's Avatar
dromano dromano is offline
Re: svx remote
Hey blokes, don't gang up on a 70 something that learned ditty bops 48 years ago, I have a hard time remembering my email address.............
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 07-31-2012, 09:30 AM
theflystyle's Avatar
Re: svx remote
going back to the pictures posted of the remote. The black wire should be attached to a metal plate that rests against the portion of the keychain (for added signal???)
did the remote end up working?
1994 SVX LSi
2008 Legacy 3.0R
Old 08-01-2012, 06:34 AM
dromano's Avatar
Re: svx remote
In the process of packing to move to St George Utah. The remote has to wait till we are settled in a new home.
My next major project is to find a 2003-04 Wrangler 2 door for all the great back country in Southern Utah. The ground clearance of the SVX won't work in sand stone country off road. It will become a semi garage queen.
Old 08-02-2012, 01:18 PM
kwren's Avatar
kwren kwren is offline
Re: svx remote
Originally Posted by CorSVXette View Post
Thank you. That makes more sense than "the steering wheel"
For sure! It is all about words...
Old 08-02-2012, 04:07 PM
dromano's Avatar
Re: svx remote
kwren, just curious, why did you post on a comment that is 5 years old?
Just curious. I apologize, I don't get it.
Old 09-29-2016, 01:16 AM
trueblue's Avatar
trueblue trueblue is offline
Send a message via AIM to trueblue
Re: svx remote
This is the only post I found about the security module, but my question was not answered so here it goes.
I have a 94 lsi, my security module is defective. The local yard has a 92 with the security module intact behind the glove box. Mine is under the rear deck. Are the modules the same or must I have one from a 94-97?
[SIGPIC][/SIGPIC]Kenyatta
The farther backward you can look, the farther forward you are likely to see. -Winston Churchill
My baby: 94 lsi
My fast baby: 2001 Suzuki Marauder
My new baby: 2010 Subaru Outback
Old 09-29-2016, 02:24 AM
Re: svx remote
The same security module with identical wires and functions.Were moved in the later years because of the passenger side air bag. Also a more responsive antenna
Old 09-29-2016, 10:29 AM
lsupcar lsupcar is offline
Re: svx remote
Why do you think your security module is defective?
I'm wondering if mine is as well.
Thanks.
Bill
Old 09-29-2016, 10:53 AM
trueblue's Avatar
Re: svx remote
Thanks for the info. svxcess.
I have no function of the security module, and the red light is always on. I am sure my problem was caused by a sticky driver side door lock. Each time I would hit the remote the door lock would react slower and slower until it finally stopped working. Soon after the alarm stopped working altogether and the red light stays on. I feel excessive current draw from the sticky door lock caused too much current flow in the alarm module and fried .
I have since remove the door lock and cleaned it well, it seems to work fine now with the key.
My baby: 94 lsi
Old 09-29-2016, 07:32 PM
Re: svx remote
Thank you true blue for that.
My remote works most of the time. Sometimes; however, the car will honk appropriately in response to the remote, but the locks will not respond appropriately. When I then use the key, the lock move easily and inside the lock sliders work easily.
Thanks.
Bill
