Old 04-12-2012, 10:47 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Re: NO MORE CLICK click CLICK START..ONLY START! starter relay
Originally Posted by oab_au View Post
"I'm getting nothing out to the starter when I turn the key.".
It is the small wire to the solenoid that has nothng?
Yes, the small wire has nothing when i turn the key. I've tried a trouble light and a voltage meter, nothing.
The sequence is, the key, security relay, Inhibitor switch on the box, starter solenoid.
Don't forget to try it in N, it case the P has a problem.
I've tried in P and N, and the dash indicator lights are accurate, but I think the contacts for the indicator lights are different than the contacts for the safety switch, so I'll jump it and see if that let's it crank. If so, I'll either replace the indicator switch or just jump it...
Old 04-12-2012, 11:29 PM
oab_au oab_au is offline
If you get no voltage at all, it must have an open circuit some where.
It would not matter how dirty or bad the contacts get, it would show some voltage.
Something unplgged?
One Arm Bloke.
Tell it like it is!
Old 04-13-2012, 12:34 PM
Hocrest's Avatar
OK, that was a lot of wasted effort for a simple fix. The 12 pin connector from the shift indicator was together, but not tightly. So some pins were making contact, but the vital ones didn't.
Yeah well, now she has a new relay and key switch, so it should be trouble free starting for a while.
Old 04-13-2012, 04:20 PM
Easy one Dave.
One Arm Bloke.
Tell it like it is!
Old 08-31-2012, 11:05 PM
jellybytes2 jellybytes2 is offline
soup IS good food
So I'm hoping this is my problem. My SVX is sitting in a parking lot a few miles from home. Stopped there for two minutes to buy some soda. When I got back there was no start. Cigarettle lighter voltage meter read okm but tried a jump just in case. Still no good. Tried looking fo the relay but couldn't find it, made miyself too dizzy hanging upsdie down, but maybe I'll have better luck in the morning. There is a NAPA store a block away. I'm hoping they have the relay.
or.. my SVX is telling me it doesn't want to go to Pocono tomorrow
'97 SVX 'Brilliant' Reddish
'94 SVX Lagina
'93 SVX Less Reddish
'89 XT6
'08 Impreza
'18 Crosstrek
Totaled
'98 LGT ~180K
'97 OBW ~185k
Sold
'89 XT6
'04 VDC Sedan
Parts
'89 XT6
'96 SVX
Old 09-01-2012, 04:55 AM
Jelly,
Did you check for corrosion on the battery terminal? Mine left me stranded last year, wouldn't even stay running when jumped. After cleaning the corrosion off the terminal it started right up and ran fine.
Old 09-01-2012, 05:16 AM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
I need to do this
Old 09-01-2012, 09:02 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Located here. Secured with a single bolt that you should only have to loosen to get the relay out.
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
(+6 with other members of the family)
FREEDOM IS NOT FREE
Old 09-01-2012, 05:32 PM
soup IS good food
Found the relay finally. Problem is with my blood pressure the underside of the dash looks nothing like the pictures. It's all swirly black with white spots under there. Napa/tunnesens had the relay but it was a no go. Fortunately it turned out to be th starter. With the remote start system I feared having to work through that wiring mess. Picked a starter up from auto zone let my mechanic swap it and I'm good to go... Except now the chwck engine light is on with an O2 sensor code. Mutter. As least I should be able to do the track day tomorrow.
'94 SVX Lagina
'89 XT6
'08 Impreza
'18 Crosstrek
Totaled
'98 LGT ~180K
'97 OBW ~185k
Sold
'89 XT6
'04 VDC Sedan
Parts
'89 XT6
'96 SVX
Old 09-01-2012, 07:05 PM
Hocrest's Avatar
The left o2 Sensor wiring runs down right by the starter. He possibly bumped the connector and it came undone?
Old 09-02-2012, 01:57 PM
soup IS good food
P0147 O2sensor heater circuit Bank 1 sensor 3 - which one is that?
/nm
'94 SVX Lagina
'89 XT6
'08 Impreza
'18 Crosstrek
Totaled
'98 LGT ~180K
'97 OBW ~185k
Sold
'89 XT6
'04 VDC Sedan
Parts
'89 XT6
'96 SVX
Old 09-05-2012, 12:04 AM
torxxx torxxx is offline
My starter has the same issue.. Too cheap to replace mine, so i just click click click click click til the sol engages lol.
I tried the relay first, and it was a no go.
92 Svx 4.44 swap 198k miles. Toyo Garit KX tires.. my Icetrack car
86 Lifted GL wagon well over 600k miles on the chassis
98 Outback 5 speed 6 inch lift, forester struts/springs 29" tires
Old 09-05-2012, 10:04 AM
Chuckls's Avatar
Designated Asshole
Yep! It's semi-embarassing in public, but when people stare at me, I give them the "One sec" sign, and when it catches finally..I wink at'em and leave.
The females love it
Old 09-06-2012, 06:02 AM
dcarrb dcarrb is offline
Be sure your battery is in good shape and fully charged, with clean and solid connections, and switch off lights and accessories, climate control, even the CD player, before you turn the key. Works for me (almost) every time.
dcb
Old 09-06-2012, 05:22 PM
The females love it
dcb
If you have replaced the Security relay and still have the problem, then do fit the Bosch relay to the starter solenoid. Simple and affective.
http://svxworldforums.com/view_post.php?post_id=35308
One Arm Bloke.
Tell it like it is!
