Just had tranny rebuilt, and .......
Just picked up my 97 ebony from the tranny shop, and had the original tranny rebuilt. The tranny shifts great, but when making turns from street to street, and turning while reversing it has a slight bind and makes a thumping noise from the rear end. The shop said all the AWD parts are brand new, as are the clutches and replaced all the solenoids. Also my speedo and odometer dont work most of the time, and when the speedo works, the needle bonces from 20 to 0. I guess the speed sensor is either no good or not on all the way
1995 POLO LSI 76K MILES SOLD |
Re: Just had tranny rebuilt, and .......
Add 3-4 ounces of a Limited Slip Friction Modifier to the tranny fluid and do some slow almost full lock circles in each direction.
A trans shop near me had to do this after replacing the clutch pack TWICE on a customers car. - That fixed it. Here's the oil they used: http://www.redlineoil.com/product.aspx?pid=41&pcid=4 |
Fact is, the shop I was talking about was using Subaru clutches, and even soaked the second set for 2 days in some kind of fluid to condition them. When that didn't work, he found that even Subaru themselves do this. It never hurts the tranny and it's not a band aid. Ford, GM, and so on use this fluid in their posi traction rear ends - are they using a band aid? Where did you get your info from? Last edited by ZMan; 09-20-2011 at 07:15 AM. |
In difficult times like these, I have to wonder , "What would YT do?". ![]()
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 09-20-2011 at 08:13 AM. |
Comparing GM and Ford rear ends to a Subaru transfer clutch... ![]() |
Yeah, you missed the point.
What part of Subaru themselves use this same method didn't you get? Do you have anything constructive to add? Last edited by ZMan; 09-20-2011 at 10:35 AM. |
A proper rebuild shouldn't need anything other than a proper transmission fluid. Worst case, do some figure 8's to break the transfer clutches in but I would not add any type of additive.
Guess, I better start doing figure 8's. How many should I do
As svxfiles suggested in your other thread, the TPS may need adjusting or replacing. Maybe you didn't notice before because the transmission was shot. A new TPS completely cured AWD binding and gear-hunting in one of mine.
dcb |
how much is new TPS?
Just called my local subaru dealer. List is $289, my price would be $207 plus tax for a new TPS. I guess I should try adjusting the current one first.
when i had my tranny rebuilt the shop said that the ultimate cause of death for the transmission was a bad speed sensor. since the trans was confused it was trying to apply the transfer clutches all of the time. don't know if this is true or not but since your speedo doesn't work maybe it's worth looking into.
