Re: Door bracket needs repair
probably any auto parts store - i have a similar, but different brand of this stuff. hard to visualize if that's something that would work from your description of the trouble, but thought i'd throw that out there.
J B WELD use both whole tube mix apply and leave it for 3 days.
Take the door panel off and drive around to a few body shops. If they don't have to do the labor of removing the panel and vapor barrier, they should be able to tell you right there if they can weld it.
If they don't want to do it, or want to take the door skin off to do it, then find a way to clamp it in place and use one of the epoxy fixes that were mentioned.
If you peel it off slowly, most of the "goo" stays attached to the barrier. Either just peel back the portion needed to give access. Or you may need to remove other rods clips or wires that pass through it to remove completely.
If you remove it, to keep it from turning into a wad of bubble gum, lightly stick it to a metal cabinet or door or something like that in your garage.
Did you ever get this fixed? I'll be up in Elmira next Thursday if you want me to take a look at it.
Not yet. I called one body shop and they assumed they would use an epoxy. There is no rush so I haven't been too active on this yet. If you are in the area, definitely we can meet up. I can come to Elmira or you can stop by the house. Let me know what works best.
