High idle at start up?
Just wondering what you guy shave for a idle at a cold start up. i think mine was around 2000 rpms today might have been 1500. It just seems a little high to me. i did just take the maf and used the cleaner on it because i was idle searching at stops and almost wanted to stall.
Re: High idle at start up?
That sounds right about normal for a suby. My buddys 97 lego GT warm up at almost 2k, and my svx is right between 1500 and 2000 rpm.
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
Check your vacuum lines. Mine has a crack and idles high and surges at times. Planning to repair it soon.
i don't know why i didn't think of that lol i have one on the passenger side of the intake manifold that was off i tried putting it on and just broke more i should fix that soon i suppose. but it is good to know that my idle is the same as everyone's
