Engine check light flashing
my svx has been stored for almost a year and eventhough that I did crank up the engine every other week, now during cold weather, the engine would die quickly during start up but works fine on regular days... I ran a read on the ECU but nothing showed up for the engine but the engine check light keeps "flashing" instead of constantly staying on.
anyone got any idea on the potential problem here? much appreciated! |
Re: Engine check light flashing
thanks! so, how do you pull the codes? from the ECU? I did that but no particular malfunction codes showed up...
I have a code reader but I think there is some procedure in the "how to" section that flashes one of the lights to tell you what the code is.
What I did was to take the kick panel loose below your fuse box underneath your dash. Locate 2 blue wires. Locate 2 black connectors. Grab the smaller of the 2 connectors and hold it notch up. With the ignition off, insert 1 of the blue wires in the top row, 2nd pin from the left. Turn key to on position but do not start car. Count your CE light for blinks. Long blinks=10 short blinks=1. There may be more than one code stored so count several times. I think this is for USDM only though. Not sure if this is what your looking for.
oops double post
Chris "A person convinced against their will, is of the same opinion still" ![]() ![]() Last edited by SoCal LS-L; 12-27-2010 at 12:53 PM. |
Constant flashing check engine light while you do the test means no codes. Irregular flashing is the CEL telling you the codes. If it were to flash while driving it usually means misfire.
Need more info..
Chris "A person convinced against their will, is of the same opinion still" ![]() ![]() Last edited by SoCal LS-L; 12-27-2010 at 12:55 PM. |
it is a constant flashing even after the engine is fired up and in driving mode too. if it's misfire, would replacing spark pulgs solve it?
I'll also look into the kick panel code reading procedure as well. much appreciated! my 100% real carbon fiber lay-over plastics + blk suede interior conversion is about done. can't wait to share! fingers crossed that the long storing for the interior conversion would not cost me major engine problems... thanks for the advice! |
would anyone know if there is a difference in the black connector and blue wire set up for 96 & newer? mine is a 96 and I could only find one blue+orange stripe wire... is that it? also, a photo of the black connector would be really helpful... thanks!!
Your car is OBD2. Go out and buy a cheap but decent code reader and pull the codes.
yes, I did have a shop done the code reading but nothing shown malfunction on the engine section... what am I missing here? sorry for my lack of better technical knowledge...
after replacing the spark plugs, the flashing remains.... experts please help!
You're going to have to get the codes checked out. If it is in fact misfiring, you are either not getting spark or fuel to one of the cylinders...
does that method apply to OBD II models? code reader reads fine and I just could not find the wiring as others have mentioned previously....
a photo of the wiring would help big time! much appreciated! |
