Old 11-30-2010, 08:49 PM
msg115031 msg115031 is offline
horn
ok my horn does not work. i have checked the fuse and the horn itself and changed the horn relay and still no horn can anyone help.
Old 11-30-2010, 08:57 PM
Green1995SVX's Avatar
Re: horn
It could be a loose connection or a broken clockspring. Does your cruise work? Airbag light?
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 12-01-2010, 06:48 AM
Re: horn
air bag light has been on since i have own the car (6 yrs) i dont remeber if my cruise works or not. what is a clockspring?
Old 12-01-2010, 11:13 AM
ZMan's Avatar
ZMan ZMan is offline
Re: horn
TRY GOOGLE!
Old 12-01-2010, 12:16 PM
Re: horn
air bag light has been on since i have owned the car (6 yrs) i don't remember if my cruise works or not. What is a clock spring?
A clock spring or is a special rotary electrical connector which allows a vehicle's steering wheel to turn while still making an electrical connection between the steering wheel airbag and the vehicle's horn and other electrical devices, such as cruise control. The clock spring is located between the steering wheel and the steering column.
It's called that because it simply looks like a clock spring that winds and unwinds. This is how a positive electrical connection is made to the airbag and still be able to turn the wheel back and forth.
The horn and cruise control circuits on the steering wheel run through this clock spring. Check to see if the horn and cruise are working. If not, you probably need to replace the clock spring.
OK, my horn does not work. I have checked the fuse and the horn itself and changed the horn relay and still no horn. Can anyone help.
Based on the above information, it seems that the clockspring has been bad for many years. How long has the horn not been working?
Old 12-01-2010, 01:10 PM
ZMan's Avatar
Re: horn
Exactly what i mean by TRY GOOGLE! - You cut out all these back and forth replies,and get your answers direct!
Old 12-01-2010, 03:27 PM
oab_au oab_au is offline
Re: horn
Well why don't you try the Cruise Control. The CC paddle runs off the horn button's power. If the paddle works, the 'clock spring' wiring is OK.
One Arm Bloke.
Tell it like it is!
Old 12-02-2010, 08:56 AM
Re: horn
my cruise control does not work. so from what i read the clocksping is bad right.
Old 12-02-2010, 08:58 AM
Re: horn
where can i get the clock spring
Old 12-02-2010, 03:29 PM
Re: horn
Maybe, you need to locate the black/green stripe wire going into the plug for the clock spring at the steering column. This is the horn button wire. If you ground this wire and the horn sounds, then the clock spring is the trouble. If it doesn't sound its not.
One Arm Bloke.
Tell it like it is!
Old 12-05-2010, 06:31 PM
Re: horn
so what you are saying to strip the greeen and black wire and ground it .right
Old 12-05-2010, 08:28 PM
Re: horn
No. I said to find the black wire, with the green stripe, where it goes into the clock spring plug. This is the same wire that comes from the horn relay, if it is grounded, the horn should work. If it does, the problem is in the "clock spring". If the horn does not sound, then the problem is back at the relay.
One Arm Bloke.
Tell it like it is!
Old 12-06-2010, 06:10 PM
Re: horn
thank you for the info i will try that and get back to you. and the relay is new.
Old 12-20-2010, 11:42 AM
Re: horn
ok i did what you said and grounded the wire(green wire with black stripe and the horn sounded. so im to understand that it is the clock spring. right.
Old 12-20-2010, 03:04 PM
Re: horn
Yes it does looks like it is there.
One Arm Bloke.
Tell it like it is!
