Selling my 94 Laguna Blue LSI
SOLD
Location of the SVX: Griswold, CT Year: 1994 Model: LSI VIN: JF1CX3557RH102172 Manufacture date: 10/93 (I think) Paint Color: Laguna Blue Interior Color: Gray Miles: around 125,586 AWD or FWD: AWD Modifications: (dates are from the invoices for the parts if I have them) 5 Speed Swap Using a 2002 WRX 5 Speed Transmission with the 2003 3rd and 4th gears installed STI Group N Transmission Mount STI Group N Motor Mounts W/Modified Brackets STI Group N Pitch Stop $15 / 15 Minute Mod Modified WRX Shifter Linkage WRX MOMO Shift Knob (01/04/2007) Wheelskins Leather Shifter Boot Modified WRX MT Pedal Set WRX Master and Slave Clutch Cylinders SS Clutch line (10/27/2006) Exedy KSB03 WRX clutch 2003 WRX Flywheel WRX MT Starter 1997 Legacy Outback MT Drive Shaft With SVX Carrier Bearing Kartboy Shifter Bushings Custom Fabricated Trany Cross Member ECUtune Stage 1v5 (6/04/2004 is when I got the 1v1 was upgrade to 1v5) MSD Stacker Ignition #7020 (6/01/2004) Accel Kool Blue Air Filter Removed Intake Resonator Stebro Stainless Steel Cat Back Exhaust System (7/24/2002) KVR Cad Plated Cross-drilled Rotors Motorsport Warehouse Stainless Steel Brake Lines Motorsport Warehouse Silicon Radiator Hoses w/T-Bolt Clamps (3/20/2005) Rotational Dynamics Ultra Lightweight Crankshaft pulley PWR Aluminum Radiator (3/02/2005) Energy Suspension Front and Rear Sway Bar Bushings (6/06/2003) Bosh 110 Amp Alternator (2/19/2002) Gentex Auto Dimming Rear View Mirror Euro Reverse Indiglo Gauges (05/18/2002) WRX Aluminum Pedals Auto Meter Lunar Tans Temp, Air/Fuel, and Volts Gauges (10/25/2002) Carbon Fiber Hood With Scoop (3/05/2003) and lifters (lifters are getting weak) 1997 Model Year Grill (04/14/2003) JDM Alcyone Clear Corners JDM Alcyone Rear Panel Delta Speed Front Spoilers (replicas, 5/04/2004) Red Powder Coated Calipers (where rebuild when painted) 6000K HID low beams Street Glow 100 Watt high beams (1/19/2002) PIAA Ion Crystal 85 Watt fog Lights PIAA 1156 Xtreme White Back up Lights PIAA 1157 Xtreme White Brake Lights LED Rear Side Marker Bulbs LED Dome Light Bulb Audio: Sony XAV-7W head unit with 7" LCD Diamond Audio M361i 6 1/2" 2 way Dyna mated doors and rear deck Major service: I just changed the new fuel filter and spark plugs with NGK iridium 5 months ago, put a new battery in the car 3 months ago, I have replaced the following; LF ABS sensor replaced (6/14/2011), PS/Alt belt and AC belt (6/3/2011), Timing Belt (6/2/2011, 125,586 Miles), Power steering pump (2/09/2005) , power steering rack (4/30/2002), water pump (4/30/2002), thermostat (4/30/2002), Left front CV joint (4/08/2008) , rear wheel bearings (8/20/2005), front wheel bearings (6/27/2011, 125k miles), center cat, both O2 sensors (5/21/2008), separator plate (10/29/2007) , Front and rear main seals (10/01/2007) , front brake pads (2/03/2009), Temp sensor (97/13/04), rear diff oil was changed (1/30/2004)( should be changed did not know it was that long ago) replaced 4 of the window stabilizers (7/08/2003) . Engine Condition: Uses oil, its not leaking, and I don’t smell it burning. Still pulls hard. CE comes on from time to time for the EGR valve. Transmission condition: around 15,000 miles on it (replaced main shaft, all bearings on the main two shafts, gears 3nd and 4th, sincrows on gears 3 and 4, the 3rd/4th shift hub was replaced (wider 2003 3nd and 4th gear parts where used and I have the invoice) (work was done on 08/17/2007) Glass condition: one very small chip low in the center Type of tire and remaining tread: Continental ContiExtremeContact 60-70% where installed 09/26/2003 but up in till 2 years ago there where only on the car in the winter, when I did not really drive the car much. Type of wheels: Stock coating is peeling on the wheels. Interior condition: good, normal seat ware on the drivers seat. Body condition: good, one lip has a chip in the paint, right rear corner of bumper has a scuff, small scratch on the left rear fender, CF hood needs to be sanded and cleared (I started to fix it, mite get it done), head lights could use a polishing. Also the front bumper and right fender where replaced around 12/10/2002 by a Subaru dealer. Do to a miner impact with a wire gird rail, was at less then 5 MPH and I can't tell that anything was replaced, also rear wring was repainted at the same time. Paint has a lifetime refinish warranty and I have all the paper work. (I am listing every little thing I know of so no one would be surprised, but other then the hood the car looks very good when clean for a 14 year old car) Known defects or problems: figure out where the oil is going, hood damper, Could also use new struts. Comments about the car: I am the second owned of the car. (title may show three, my parents have there name on the title when I got it) I have owned it since it had 60,000 miles on it. I always use synthetic oil and change the filler about every 3,000 miles. I have many of the invoices for part that are on the car. I loved this car and put a lot of money into it (3K+ in audio and another 3K+ into doing the 5 speed swap, the hood, all the JDM parts, and the exhaust), but I got a 2002 WRX and now my SVX mostly sits. So would like to move on at this point and sell it before it gets trashed from sitting. Parts that are most likely going with the car: Stock Review Mirror Extra rear window switch Extra dash switch Set of new valve cover to breather gaskets New WRX Shifter socket bushing NAPA PCV Valve Parts that I have for the car I would be willing to sell: Set of 18" focal F5 wheels with shot tires and locking lug nuts 90 Durameter Polyurethane Front Swaybar Bushings 90 Durameter Polyurethane Rear Differential Mounts Pics are here: http://www.cardomain.com/ride/195581...griswold-ct-us Asking price: Would like to get $7,000 with the extra parts and the audio stuff, lower without parts and audio, but BO would do. People let me know what you think or if you have any interest at all.
2005 Legacy GT 2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles My WRX's Cardomain Page Last edited by AFBeefcake; 06-17-2011 at 08:28 PM. Reason: Updated |
Re: Thinking about selling my 94 Laguna Blue LSI
Somebody is going to get one of the nicest blue SVXs I've seen in pictures. I have always thought this car was very sharp. Manual swap is just that much better.
Good luck with the sale.
"What you plan, and what actually happens ain't exactly ever been similar..." ------------ 1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it. 2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan. 1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun. |
Good luck with the sale. That is a very nice car.
One question, WHY ?
I added dates to all the parts I had invoics for.
As for why, Well. 1) I got a newer toy, VF22 powered 2002 WRX. Its cheeper for parts and better as a daly driver. 2) We don't need three cars for 2 people. 3)I dont have a coverd place to park it and keep it out of the weather. 4)We dont drive it very much, blocked in by the other two cars. 5)It realy needs work to get it where I want it and I realy don't have the money to do that. I would need to get coilovers $2000 , new summer tires $1000, wheel bearings $500, and I dont know where the oil keeps going. So looking at around $4k to get it where I want it and then it will still be a 14 year old car that i have no place to keep. Dont get me wrong I love the car. Its rare and fun. If I had the money and a place to keep it I would keep the car. but I don't and its sad seeing the car just sitting in the drive way every day. Its time to move on before its not worth anything to anyone but me and I could realy use the money to pay off bills right now.
I drove this car to work daily for a little while when a friend was using my wagon.
I LOVE this car and I too am sad to see it sit in the driveway on a daily basis. And yes, I will be sad to see it go as well. But as my Husband (AFBeefcake) said, it's time to let it go. I know there is someone out there that can really take care of her and make her what she was meant to be. And yes, we could really use the money to pay down some bills. The car still has rediculous power and is so much fun to drive! |
WOW! Sad to see you selling this!
Used to drool over this daily on the WNEC campus! Only got to talk to you once (94 Pearlie), but saw your car countless times. SUPER clean! Good luck with the sale! I would love to take it off your hands, but for all of the same reasons, my '06 WRX suits me just fine!
'06 OBP WRX '03 Ninja 636 '94 Pearl SVX LSi (sold) |
Interested in trading for a 2005 LGT? You are only about an hour away from me too...
How many miles on the LGT?
Yes and Yes.
anyone have any intrest?
Anyone? at all? This really is an awesome SVX.
If my LGT sells consider it sold...
Just bumping this.
If you change your mind on the trade let me know...
