Oil gauges.
I have been try to chek out how to innstall a oil-pressure and -temp gauges.
Are the some contak on the engine or must it bee drill a hole in the block to too this. I have find a extrapart to the oil filter to read this. Like this one. ![]() but i dont know how this is. ![]()
Alexander (Norway) My subarus: 1992 Svx LSI 5-MT(3.54) 1998 Legacy BG 2.5L GX |
Re: Oil gauges.
The oil pressure sender unit on my car is running from the location of the stock Oil Pressure sensor (on top of the engine slightly behind the Alternator). Tom used a T fitting and sensors screw in on the opposite sides. Seems to be the easiest way of doing it, for wiring and for read out purposes since this is the spot the stock oil pressure sensor is located in.
Re: Oil gauges.
Ok. Thank alot for the answere.
Re: Oil gauges.
there are aftermarket galley plugs available as well. this will allow you to use any oil galley plug as a tap for the sensor.
Tom |
Re: Oil gauges.
Re: Oil gauges.
I will be replacing my alternator hopefully this weekend. Will snap a pic or two of my set up.
-Sov13t. |
Re: Oil gauges.
Re: Oil gauges.
If yo get a galley plug tapped for the sender it would look something like this
![]() Not sure it would fit under a stock manifold Tom |
Re: Oil gauges.
And here is a pic of mine:
Re: Oil gauges.
Thanks alot for the Pictures.
