Old 05-23-2010, 02:06 AM
Dessertrunner's Avatar
Building an engine dyno.
Over the last couple of months I have come top the conclusion that we basicly have no solid number on what each mod will do to our engines as regards power. We make a number of changes and have no idea if they all worked or only some.
I have redesigned the roller throttle port size lots of times and clearly have no clear idea which is best. Having read that recent artical I have change my mind again so i want to be able to run tests to be able to give clear direction.
Okay enough reason, now to "HOW I THINK I WILL DO It",
I am talking to a guy to buy a "Eddy Retarders from a truck" this is then anchoured with a strain guage to measure the torque and a prox reading revs.
From that you get to calc HP and torque at the different revs.
Was going to use a water pump but they have issue and are a bit difficult for me to find.
Tony
Old 05-25-2010, 05:22 AM
Re: Thinking of building a engine dyno.
You guy are pretty quite,
I paid for the Telma eddy Retarder today (PDF of the unit is attached). It provides the load for the engine. A shaft is connected to the front and back for support with the front attached to a pulley and chain driven to a shaft driven from the engine. Eddy current units are limited to around 4,000 rpm so thats why the cahin drive. I am using 2.5 reduction to enable the unit to read up to 10,000 rpm on the motor & 1,600nm.
The centre section of the retarder is floating and will be fitted with a 1 ft lever at the end of which is a strain guage (set of scales). At any point in time its just a simple matter to read the pound weight and you have the ft pound the engine is producing. At the same time measure revs and you can calc the HP being produced.
I am ahead of myself a bit we control the load on the engine by feeding between 0 to 24vDC to the coils (using a old electric forklift charger) on the retarder as required to keep the engine at full load.
I recently purchased a half cut and I will pull the ECU and wiring harness from it to enable me set up the test bed.
My plan is to start with a stock standard low k engine (100,000 kilometer is low to me). Attach it as if it was in a car, full exhaust, standard intake then do a couple of base line numbers.
Then with out touching the internals of the engine I want to see what can be done to get more power from the out side, extrators, different ECU (have got the Wolf going), different injectors & roller throttle. All of it one step at a time to put solid number at each stage.
Okay thats it for me for the moment will keep you posted as I go, given that it is the slow part of the year (only working 60hour now) for me I want it all built and running in the next 6 weeks or sooner.
Have a great day all.
Tony
Old 05-25-2010, 06:05 AM
Good luck Tony
Old 05-25-2010, 08:52 AM
Nomad Nomad is offline
The car named NIGHTMARE
Send a message via MSN to Nomad
I'll be reading that ! Very interresting to know real numbers.
Nightmare is the name of the car...
Old 05-25-2010, 02:13 PM
was also thinking about build/purchasing one a while back... Quickly realized it would be cheaper albeit inefficient on time to just dyno the car on a chassis dyno
Old 05-25-2010, 03:06 PM
I had the same thought Tom and agree that is cheaper.
Clearly thought you never get the research done that is need to develop the SVX engine. Take for example cams. On a engine dyno you don't run timing belt covers, and when you want to change the cam its a simple matter. If the engine is in the car you have to pull it, put it back everytime.
I don't know of any serious race engine that has been developed that hasn't spent time on a engine dyno.
Besides a guy needs a hobby to keep him off the streets.
Have a great day.
Tony
Old 05-25-2010, 06:14 PM
Have a great day.
Tony
That would have bee the sole reason to build one for me... I can change a manifold in the car... Change a header in the car... But cams... it can be done w/o pulling the engine but what a PITA!! Good luck!
Old 05-25-2010, 07:13 PM
Thanks Tom, I may need all the luck I can get.
We need to get a discussion going about what we all would like to acheive in the end and how best to step through to that point.
Tony
Old 05-25-2010, 09:44 PM
Boxersix's Avatar
Boxersix Boxersix is offline
Porsche Autofanatiker
Lolz, I just like ours . Except it's a water brake dyno, good for ~1000BHP
Old 05-25-2010, 10:06 PM
Adam do you find engine dyno's handy, I read one guy say "The engine dyno always comes before the car dyno" what do you think?
Tony
Old 05-26-2010, 02:59 AM
NeedForSpeed NeedForSpeed is offline
Another fascinating thread from Tony, what fun to measure the changes!
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 05-26-2010, 05:45 PM
oab_au oab_au is offline
Tony the hardest part of building the eddy current dyno, is getting rid of the heat that is produced. If the engine puts out 180 kW, you have to get rid of 180 kWs of heat.
The water or "Froude brake" uses the water to dissipate the heat. The Eddy current has to be air cooled, so it can only be used for short runs.
One Arm Bloke.
Tell it like it is!
Old 05-26-2010, 07:20 PM
Hi Harvey,.
Thats true so the way I get round it is to use a unit capable of handling 1,600nm which is way over kill. It is also open to the air so the unit provides self cooling. As I understand it the cooling of the unit can handle lower heat levels for long periods.
Should be interesting.
Tony
Old 05-28-2010, 02:43 AM
The retarder was delivered, as they say its a big mother. I put an injector so you can get a idea of the size.
Tony
Old 05-28-2010, 05:30 PM
It does look like it could dissipate the heat OK, if it is feed plenty of air.
Ozzie ingenuity at its Best.
One Arm Bloke.
Tell it like it is!
