My '92 is in great shape- runs smooth- but new problem....at times when accelerating for some reason the engine just dies!! Have to pull over asap and put into park and restart- Have added fuel cleaners...Any ideas??
Re: Engine Sometimes Cutting Out on Acceleration
I would start with the MAF. Easiest way to check it is to replace it with a known working one. You can also attempt to fix yours if it is repairable. There are documents in the How-To Documents.
Seconded, do you have a check engine light on? Even if not, id still check for memory codes, just in case something was stored.
thirded ? how u say i am third aproving ?
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008" rest in pieces Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill |
Random or sudden stalling, it would seem is the MAF. It was in my case too.
Mac __________________________________ 1995 SVX-L AWD, green, 98,xxx miles, ECUtune 1.5, mazda RX-8 wheels with subie center caps, stebro muffler, resonator delete, koni inserts, perrin crank pulley, hella 500 off-road lights, power-slot rotors and ..... 1993 968 Coupe 6-speed, 80,xxx miles black, H&R springs |
I hate to sound stupid, but what is the "MAF"? I don't see it in the How To docs......Thank you all for your help on this!!
MAF = Mass Airflow Meter its attached right to the box that houses the Air Filter..
Again, I hate to appear idiotic, but I can't find which articles in the How-To Docs cover the MAF....Please take the trouble to continue steering me in the right direction.....MUCH APPRECIATED!!!
1992 SVX LS-L: For sale 1995 Lexus SC400- Lexta Z |
