Old 01-02-2010, 10:47 AM
jjanak79's Avatar
jjanak79 jjanak79 is offline
oil weight.
Do you guys suggest to run 10w30 in the summer? I have 5w30 in it. it leaks a lil from the valve cover, but wondering if that is a good idea.
94 Subaru SVX FWD 51k
04 Mazda B4000 (work truck)
Old 01-02-2010, 11:05 AM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
Send a message via AIM to Stevebsy Send a message via Yahoo to Stevebsy
Re: oil weight.
I run 20w-50 in mine all year round, but I live where it is never below 40 degrees F.
In the owners manual is a chart that shows what weight for what temperatures you should use.
'93 Anniversary Edition SVX 122k - 3.7 FD 5MT Swap, ECUtune 1a1, Bontrager RSB, Mad Restoration underway!
'20 Honda Ridgeline
Custom Oil Caps, Battery Bars, Phenolic Spacers for sale here:
http://www.x35design.com
Old 01-02-2010, 11:10 AM
jjanak79's Avatar
Re: oil weight.
ya its -11 right now. I dont have a owners manual for it actually. otherwise i would of looked at that.
Old 01-02-2010, 11:57 AM
Nevin's Avatar
Nevin Nevin is offline
Re: oil weight.
Recently I started using Mobil 1 0w-40 synthetic.
My valve covers do leak a bit now, but I know that they need to be replaced anyway.
The first number in the oil description is the low side of the temperature range. 0 being the best because it can operate at extremely low temperatures. The second number is the high end of the range. Higher numbers have excellent wear characteristics but don't work at as low of temperatures. A 0w-40 is great because it doesn't sludge up in cold temperatures, and it can protect as well as a 40w.
Anyway, that's my take on it. It was 20 below 0 this morning plus windchill and the car started just fine. Last year at this time I had to jump it a few times because it cranked much harder. So I am convinced that it is doing the job.
Jesus is the remedy
2015 Expedition EL Ecoboost
Ebony Pearl '95 Subaru SVX LSi
Home of the Bontrager Works 22mm rear sway bar!!
Old 01-02-2010, 12:22 PM
Re: oil weight.
I don't have any extreme temperatures, so I run what they suggest - 10 - 30, but I use a synthetic/regular mix, and change it at 3,000 miles.
Old 01-02-2010, 12:30 PM
Old Fogey
Re: oil weight.
Per the tables you're right at the bottom of the 10w30 range at -11degrees, with 5w30 recommended. But since you're asking about summer operation, 10w30 or 10w40 is the recommendation. There is a specific warning however about NOT running sustained high speeds with 5w30 in the sump.
Glenn
Old 01-02-2010, 03:25 PM
RoughSilver92 RoughSilver92 is offline
Re: oil weight.
Glenn
Exactly. That's been enough to scare me away from the 5w30 for this car.
(10w30 for me)
Old 01-03-2010, 01:40 AM
kwren's Avatar
kwren kwren is offline
Re: oil weight.
(10w30 for me)
Please define "high speeds"
Keith
Old 01-05-2010, 12:12 PM
Cam Cam is offline
Re: oil weight.
faster than slow speeds, yet slower than extreme speeds
Old 01-05-2010, 09:56 PM
kwren's Avatar
Re: oil weight.
Thanks!
Keith
