Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Transmission and Drivetrain
Old 10-10-2009, 12:11 PM
yt yt is offline
Cracked a Flex Plate or worried about it??
If you have your engine and/or transmission out this is a required purchase.
Subaru Part #12332AA071
This is the Phase II flex plate that is a direct bolt up for our engines and our Phase I transmissions...
The old style plates are 2.05mm thick according to my micrometer
The new style plates are 3.25mm thick
Just figured someone may need this info. If you have a hard time finding one, let me know, I ordered 3 and need one, so there are two on the shelf
Old 10-10-2009, 02:46 PM
yt yt is offline
Re: Cracked a Flex Plate or worried about it??
Sorry for camera phone pic but you get the picture
Old 10-10-2009, 03:32 PM
sowise sowise is offline
How much are you selling the ones on the shelf for? I believe I have an order in for heads and steering rack maybe we can work something out once I send back the cores?
Old 10-10-2009, 06:42 PM
yt yt is offline
Yea, I will throw one in for you free of charge. I am hoping to have the heads back from the machine shop next week so I can begin lapping the valves and reassembly. The rest is waiting to ship with the heads correct?
Old 10-10-2009, 07:57 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Interesting design. Thicker material should definitely help.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 10-11-2009, 07:28 AM
Thank You!
The heads, steering rack and Group N mounts can pretty much come together I am not in a rush just yet since I ordered my engine seal kit last week.
As soon as the heads arrive I will pull mine and get them out to you. Would you perhaps like me to ship my flex plate back I don't believe it is cracked or damaged I just felt like upgrading.
Old 10-11-2009, 09:55 AM
yt yt is offline
Originally Posted by sowise View Post
Thank You!
The rack and the old heads are all I will need back from you. I have a ton of flex plates here already, but there is no good use for the old ones
Old 10-11-2009, 09:57 AM
yt yt is offline
-Bill
its drilled for weight. The PhaseII flex plate is still heavier even with all the material removed.
Old 12-02-2009, 07:48 PM
Wocketman Wocketman is offline
YT,
What are the symptoms that indicate one might need the new beefier plate?
Bruce Schwab
Recovering solo ocean racer
www.bruceschwab.com
On land: 92 Ebony SVX, 188k
Old 12-02-2009, 08:26 PM
A broken one
Old 12-03-2009, 05:19 AM
Originally Posted by TomsSVX View Post
A broken one
Har har...what would one notice when driving with a broken one?
Bruce Schwab
www.bruceschwab.com
Old 12-03-2009, 09:10 AM
subeman90's Avatar
Soobologist
the total lack of any movement from the car. Broken plate does not turn the TC and then the shaft doesn't turn and then the pump doesn't make pressure and since there is no pressure there is no movement. Engine will run fine and rev fine but the car will not move.
15 OBW premium w/eyesight
Old 12-03-2009, 09:28 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
If it's broken that bad, the car won't start, the starter would turn the TC and the trans, but not the engine...
Generally if it's cracked, it will make a loud clicking at times.
Old 12-03-2009, 12:32 PM
subeman90's Avatar
Soobologist
but if the car is already running.... it will free rev.
maybe you should tell this story...aren't you the king of cracked FP's?
Old 12-03-2009, 08:05 PM
Hocrest's Avatar
huh?? I had one that I found to be mildly cracked when I pulled the trans???
Now failed tranny's? Yeah you could call me the king of them...
