Voltage of the blower motor on high?
Took my svx into the shop because it was throwing oil onto the windshield and they resealed the engine and replace the idler pulleys... then after my blower motor craps out and i get an O2 sensor failure
Re: Voltage of the blower motor on high?
![]() Sorry, Keith ![]() |
Lots of SVX blower motors on Ebay for cheap.
I would highly recommend properly lubricating any used replacement before installing it. Sort of a hassle to replace the thing.
Keith ![]() |
Well, I tore my hands apart getting to the dang motor, but after using a voltmeter anything under 1 amp kills the blower circuit even at 12 volts, so i'm sure i have a bad wire somewhere in the harness... but the control works just fine, so tomorrow i'm going to try and figure out a good fuse to jump from, cant use the clock and one of the heater harnesses already blew 3 fuses, only wasted 2 10 amp fuses from the clock/lights, but the heater is just useless, i could direct splice into it and nothing though i understand the 5 amp change
