Old 09-13-2009, 08:02 PM
Re: 11:1 CR Race/Street Engine build
Teaser pics. Sorry if they are out of focus... this is what happens when you let Eric touch the camera
Old 09-13-2009, 08:04 PM
Originally Posted by SVXRide View Post
YT,
Did a little checking. Can you confirm that you'll want shims that have a Rockwell harness of 45 or greater?
-Bill
Bill HRC 45 should be pretty good.
Old 09-13-2009, 08:16 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Cool. High carbon steel it is (1095ish, if my memory serves me right). I'm guessing they may need to be heat treated after machining due to the heat imparted by the machining. We're basically talking about tool steel/knife blade material here.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-13-2009, 08:18 PM
-Bill
It would be a good idea to heat treat it if they have the facilities to do it. I know I do not aside from heating and flashing in water
Old 09-14-2009, 03:05 PM
You also need to show us pictures of the auxiliary water tappings...
Remember, always prove what you declare
Old 09-15-2009, 04:48 PM
Danny have not tapped them yet. I am picking up the fittings and hose this week though
Old 09-16-2009, 01:36 AM
This will be interesting to see...
Old 09-16-2009, 07:04 AM
I just found THIS source of shims also Tom. They are overseas though but priced good in my opinion. Shipping should be cheap...
Old 09-16-2009, 03:00 PM
Dessertrunner's Avatar
Tom,
I totally agree with you about the cross over pipe and its causing the left bank to not get enough cooling as we understand it that bank boils even when the radiator is running cool. The guy with the buggy still hasn't been able to keep it cool so we are going to cut the cross pipe today and raise the height. Happy to post photos when and give feed back to the degree of success or failure.
Tony
Old 10-03-2009, 08:52 AM
after numerous emails and phone calls, I cannot find the proper size shims anywhere...
I had the thought of trimming down the valve stems to create a larger gap to use thicker shims. I would rather not do that in all honesty.
SO.... I have ordered some Yamaha motorcycle shims. 25mm in diamter and 2.30mm in thickness. I will send these out to be cut down to the individual thicknesses they need to be.... Anyone else doing this... Highly suggest trying to take 1mm out of the base circle
Old 10-03-2009, 11:11 AM
Camshaft base circle?
Old 10-03-2009, 11:22 AM
FriendlyTurkey FriendlyTurkey is offline
Are you running into this trouble since you are using stock length EJ20 valves instead of the shortened EJ20 supertech valves used on the EFI logics car?
Old 10-03-2009, 11:43 AM
He mentioned earlier he used Crower valves, I guess they are stock length.
EFILogics are 0.5mm shorter...
Old 10-03-2009, 12:23 PM
yes reduce the bas circle.
Yes they are stock length valves
Old 10-03-2009, 09:22 PM
oab_au oab_au is offline
I wouldn't worry about HONESTY you do what ever you have to.
A lot of engines are done like that.
On Desmodromic Ducatis the shim top and bottom of the valve are usually rubbed down to size on an oil stone to suit.
The only difference whether you do the shim or the valve, is the cost. We know which is cheaper.
One Arm Bloke.
Tell it like it is!
