Old 08-21-2009, 03:26 PM
ZMan's Avatar
ZMan ZMan is offline
Smile SVX Grille Lights
The SVX grille was asking to be modded.
It looks like a light but it's not.
I decided to make it useful by incorporating my alarm status into it.
Really stands out in the dark and there is no doubt that the alarm is armed!
It is shown running in demo mode which goes through most of it's patterns, but I usually leave it set to just a single pattern.
And yes, I know about the other Knight Rider Svx mods.
http://www.youtube.com/watch?v=f1MxYFqJR-8
Old 08-21-2009, 04:00 PM
Re: SVX Grille Lights
That's cool. Can it dance to music?
Old 08-21-2009, 04:57 PM
BRADY's Avatar
BRADY BRADY is offline
SVX Addict
Send a message via MSN to BRADY Send a message via Skype™ to BRADY
I like it! What alarm system are you using? How did you modify the grill?
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com
Old 08-21-2009, 07:11 PM
For those too lazy to click on the link provided...
I want green LEDs for the Polo
Old 08-21-2009, 07:34 PM
nsm484's Avatar
nsm484 nsm484 is offline
Teh Geek
Send a message via ICQ to nsm484 Send a message via AIM to nsm484 Send a message via Yahoo to nsm484
Agreed! Where's the How-To Already?
-Roger H. | Website - nsm484.com | Facebook - Roger Harvey | Twitter - nsm484 | Personal Locker
2002 Mitsubishi Lancer OZ Rally [Nori]
1996 LSi Polo Green [Calista] - 18" Konig Incident's - Lived for awhile Now Selling
1992 LSL Dark Teal [Yori] (Rear Ended, Donor to Calista, and now gone)
1992 LSL Ebony Mica (Sold to svxcuseme)
Old 08-21-2009, 08:15 PM
ZMan's Avatar
OK, the light bar I got off Ebay - 22 in. long, a perfect fit.
Drilled a 3/4 in. hole at each end of the grille. - should have taken pictures.
Slid the light bar into the grille and attached it inside with a plastic epoxy - it is a stick of epoxy in 2 parts you knead together to mix - has the consistency of clay.
After it hardens I sealed the ends with a small piece of aluminum tape thats used for home a/c also a little RTV around where the ribbon wire exits.
Any alarm that has either a 12 volt or ground when armed will work. - Ed
Ownbot's Avatar
Ownbot Ownbot is offline
I'm the anti-do-gooder
Are you Michael Knight?
Is that Knight Rider?
and btw, is that your house in the background? It's very nice!
Old 08-21-2009, 08:20 PM
ZMan's Avatar
Thank You.
Old 08-21-2009, 08:33 PM
nsm484's Avatar
Teh Geek
Can you link the Light Bar? Because not all light bars have sectional control, most are just all on/off.
Old 08-21-2009, 08:45 PM
ZMan's Avatar
Red Bar:
http://cgi.ebay.com/ebaymotors/New-5...d=p3911.c0.m14
Blue Bar:
Old 08-21-2009, 09:16 PM
Banned
is it possible to use this technology with the rear turn signals and make a scan from left to right and right to left respectively. how much would it cost??
Old 08-22-2009, 08:22 PM
Found the green LED light Bar at Knightlight.co.uk HERE. A little pricey at $161.00 plus shipping.
Also available in blue, yellow and red for your viewing pleasure
Old 08-22-2009, 08:36 PM
ZMan's Avatar
That was the first one I looked at, but I believe it's too big to fit inside the grille without major surgery.
Old 08-22-2009, 08:50 PM
Here are the specs and additional photos:
Total width including polycarbonate: 486mm (19")
Depth: 58mm (2.25")
Height: 6mm (.25"), 10mm on the larger circuit board (0.4")
Scanner Light Width: 448mm (17.75")
Scanner Light Height: 6mm (.25")
64 LED / 17,000mcd / super bright, brightest and most powerful LEDs available
Power consumption: (when running single bar pattern.) <110mA
(A 12W bulb, like an indicator bulb, is 1000mA, which uses almost 10 times more power)
Probably the easiest thing to do in cut the bottom of the grille out, attach the LED assembly directly to it and reseal.
Old 09-16-2009, 08:27 PM
ZMan's Avatar
I found out that the people I got the red light bar also had it in green as well as the blue.
Here's the green in my polo green '96:
