click click click...start? click click start!
so i turn the key to start my baby and she clicks...is it starter? starter solinoid? ignition switch?
help please..sorry if this is a repost..i cant search the message archives for some reason? help there too? running vista32 bit with IE8
VICSVX 94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx |
Re: click click click...start? click click start!
search "how to do the bosch relay mod"
Tom |
This will probably overcome the fault. But as I have advised many times, will not fix it. N.B. Refer last page, current post, "Lets talk about this annoying hot start problem".
The Bosch relay has started my car several thousands of times without fail since I did it! There is no other known solution to this problem.
If this is not a "fix" it is danged close! Cheers, Trevor Keith |
However...
We pray a lot! Keith |
That the existing fault will not develop further, on a cold and rainy night.
Yeah, I put in the Bosch Relay and still have clicking problems with hot starts . Could be that the relay went bad though...
my sunfire did this to me . the problem was a loose cable that goes to the starter...have an eye
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008" rest in pieces Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill |
However, with the Bosch relay sitting there, easily assessable when I open the hood, a simple screwdriver touching across the 2 Bosch relay terminals with the key turned on to the run position and the SVX in park, providing the instant start! Another praise the Lord! on the road again. Trevor, I am just dying for the day that you hop in your SVX and start the engine, rather try to start the engine and you get the click that so many of the rest of us have experienced! Not wishing you any bad luck because this is one of the cheapest and easiest mods possible. When this happens, please take your camera to the auto parts place and get us a picture of you standing at the counter with a Bosch relay in your hand and give us a big smile while the camera clicks away. Another "not so bad click". On your post, please end with... Please see attachment! Cheers, Trevor! Keith |
Tom |
How about we recommends that da guy cleans both ends of his main starter cable, then if that doesnt work, pull the starter and bench test it. |
Keith Last edited by kwren; 08-02-2009 at 11:40 PM. |
With so many cars apparently having this trouble one might think that someone would have isolated the culprit by now.
dcb |
Best to take the logical approach and properly check for voltage drop, all along the tenuous electrical path involved, which includes many sets of interlocking control contacts.
Two main things remain when you have a starter click but not turn the engine: Dirty contacts not allowing enough amperage to turn the flywheel, or a bad starter. I have seen both many times, thats why the next logical step is to clean contacts, then bench test the starter. Ahhhhthankyou! |
