Old 07-16-2009, 08:05 PM
oab_au oab_au is offline
Re: jdm svx trans, will it work?
Originally Posted by oab_au View Post
Yes you will need a 3.7:1 rear diff, and swap the C solenoid for the US one. Then use the US TCU.
A bit late to do this now, so it is either swap the TCU with its "speed limiter" or do the C swap.
One Arm Bloke.
Tell it like it is!
Old 07-16-2009, 08:26 PM
Hondasucks's Avatar
Subaru Technician
All you need is a circuit that will invert the signal going to the solenoid. Since on the JDM trans full power = AWD, not FWD as in the US model. Wouldn't be all that difficult, and probably lots easier than getting a JDM TCU. I'm sure I could come up with a circuit that would work, I'd just need some time!
1986 VW Jetta
Old 07-16-2009, 10:21 PM
I thought the ECU was the speed governor for the JDM models?? Hence the code written into them for it and the JDM ECU having the hardware to make it work.
Old 07-16-2009, 11:09 PM
Trevor's Avatar
Trevor Trevor is offline
Originally Posted by TomsSVX View Post
yes
The JDM trans' center diff works on an opposite method so when the TCU commands FWD the trans will apply AWD. You will need the JDM TCU. Whether it will plug right in is the only thing I am not sure of
Exactly which solenoid do you now have you fitted? JDM normally open, or US normally closed?
It is the different solenoid which reverses the “command” of the TCU signal. When using a JDM transmission, you must fit the appropriate C solenoid valve, i.e. one that is normally open and NOT the US one which is normally closed.
You should also be using the JDM TCU, otherwise as I have pointed out, the programming will/may not be correct, which is no doubt the current situation. The US TCU is programmed for a clutch, the JDM for a differential.
Trevor, New Zealand.
Old 07-16-2009, 11:11 PM
would it not have the same effect and still maintain the proper programming if you simply used a JDM TCU?? This is the right way to do it in my mind
Old 07-17-2009, 01:16 AM
Trevor's Avatar
Greetings Tom,
I agree that it is confusing, but no.
Please refer --- http://www.subaru-svx.net/forum/show...t=35942&page=4
Cheers, Trevor.
Old 07-17-2009, 05:48 AM
Originally Posted by herffstyle View Post
I have an update,
everything is installed, tranny, rear gears with SVX LSD.
I drove the car down the road and all was well at low speed, when i needed to turn it felt strange, kinda like a 4x4 truck in 4wd on pavement. So i belive the center diff is locked or something.
I dont really know how the center diff is set up in the JDM.
I am using a US Spec TCU.
other than that it accelerates quickly and shifts nicely.
Anyone have input?
Think the JDM TCU will fix it?
Thanks
Steve
Steve
Aside from the debate about whether you should be using a US spec Sol C or a JDM spec Solenoid C, I'm of the opinion you should be using a JDM type TCU to control that gearbox.
The TCU has different maps for each gear It uses a large range of data inputs to ensure traction works, and that it works in tandem with your ABS. Essentially you are now using [US] maps that vary traction from 10% rear standard mode to 50% rear under hard acceleration which is the US gearbox specs.
These US traction maps are incompatible with the gearbox you now have fitted, which has normal standard distribution to the rear of 64%, varying upwards to 50% under hard acceleration [VTD maps, JDM traction control]
Were you to completely disconnect the signal to Solenoid C, I would suspect in default mode your gearbox should operate permanently at 36% front and 64% rear and be entertaining to drive. I'm wondering if perhaps with the signal your American TCU is getting from the Solenoid C that the incompatibility issue may be causing it to lose its marbles and go to 50/50 lock up?
Also, the symptoms you describe sound like 50/50 centre diff lock-up. Please check if the fuse is inserted under the hood. In the US cars, inserting the fuse causes 100% front wheel drive, and does no harm. With the JDM gearbox, inserting the same fuse locks the centre diff 50/50, and will do harm if you keep driving in that mode.
My best advice is you need a JDM style TCU. Even the UK/OZ type will be less than ideal. It will have the correct traction maps but uses different speed input data.
BUT CHECK THAT FUSE IS NOT INSERTED!
Old 07-17-2009, 02:16 PM
Trevor's Avatar
Joe,
Please do not add to the confusion. There is no debate regarding the different C solenoids fitted to the US clutch system and the JDM and others using a centre LS diff. Without doubt, the solenoids are different as has been stated. The reason is clear and not difficult to assimilate.
Trevor
Old 07-17-2009, 02:40 PM
No debate?
Originally Posted by Trevor View Post
Joe,
Trevor
Hey Trevor, I thought I was elucidating on the subject.
No debate on the C solenoids? You could have fooled me. When you have Tom and Harvey and you, and a couple of others to boot, throwing in suggestions that differ, I take that to be a debate, am I mistaken?
Plus I think Tom and you and I have essentially said the same thing, use a JDM type TCU? Hopefully that does not add to the confusion.
Old 07-17-2009, 03:15 PM
Greetings Tom,
Cheers, Trevor.
It just makes no sense. If you have the JDM trans and a JDM TCU it will essentially be a JDM car (not m4[) jdM y0). So unless there is a problem with the way a JDM performs, it is incorrect to us a US solenoid in a JDM trans with a JDM TCU
Old 07-17-2009, 03:22 PM
Trevor's Avatar
Re: No debate?
There is no debate and simply incorrect statements by Harvey.
I have proven what I have stated is fact with detailed information. If in doubt please physically check your own cars which have a centre diff. The C solenoid will close when energised, i.e. it is normally open. Also refer post in the opposition forums from a member from Norway, requiring a C solenoid.
Trevor
Old 07-17-2009, 03:33 PM
More or less I think we are all saying the same things, just mixed it all up. From what I have gotten from all this and my understanding of how they all work here are a couple scenarios
Trans-TCU- SOL C
US-US-US
JDM-JDM-JDM
JDM-US-US
US-JDM-JDM
basically as long as the Sol C. Matches the TCU being used it will function properly. Thats my understanding and why anyone would need to make it more complex is complex in itself
Old 07-17-2009, 03:41 PM
Trevor's Avatar
Trans-TCU- SOL C
US-US-US
JDM-JDM-JDM
JDM-US-US
US-JDM-JDM
The TCU and solenoid must match the transmission. i.e. US-US-US, or JDM-JDM-JDM, are the only arrangements which will work correctly.
Old 07-17-2009, 03:46 PM
Thats what I was saying originally but you told me it required a US solenoid if you were going to use a JDM trans and TCU... hence the confusion... Maybe I just read it wrong
Old 07-17-2009, 04:00 PM
Trevor's Avatar
Please Tom,
If in any way I posted a confusing statement advise where, so that I may quickly apologise and correct same. Throughout my aim and intent has been to retain accuracy within the thread, in order to prevent the annoying confusion which has been established as a result of incorrect statements.
Sincerely, Trevor.
