Re: Loss of Heat
I tried flushing the heater core again and am still having the same problem. One thing that seems odd is that when I turn the heat on at max flow it is warm initially for a few seconds then goes right to cold. I have code 15 coming up when I check the codes and I do not know exactly what code 15 is, anyone know what this is and where it is located?
06 Ford F150 Crew 4x4 142K+ miles 05 Volvo XC90 163K+ miles 02 Toyota Camry 170k+ miles |
Re: Loss of Heat
Check the system details here: http://www.subaru-svx.net/photos/files/How-To/14349.pdf Assuming it is a bad sensor I would consider this good news. At least you know what is the problem and a new sensor should fix it. Joe ![]()
Re: Loss of Heat
Elazar '08 ML550 daily driver '13 F150 work truck '87 MR2 racecar '92 Lsl Claret 5sp "Be kind to your motor car." - Jackie Stewart |
Re: Loss of Heat
Just the same, the underlying system for heating/cooling is fundamentally the same for all SVXes. In other words the fault codes and the parts numbers for all models will be the same, with the obvious difference that the control module is more sophisticated in the Euro/Japanese cars. In answer to your question if you have pulled Code 15 from the aircon diagnostics on your '94, it will be the same thing causing the problem, either the refrigerant temp sensor or the wiring to it. [edit] or possibly the auto amplifier if both above check OK. Scroll down and read the troubleshooting for Code 15 [/edit] Joe ![]()
Black Betty [Bam a Lam!] '93 UK spec, still languishing Betty Jersey Girl Silver '92 UK [Channel Isles] 40K Jersey Girl @ Mersea Candy Purple Honda Blackbird Plum Dangerous White X2 RVR Mitsubishi 1800GDI. Vantastic 40,000 miles Jersey Girl Last edited by svxistentialist; 03-19-2009 at 06:36 AM. |
Re: Loss of Heat
Ok thanks for the answer Joe. My problem is no heat or a/c at all so I was thinking probably just a thermostat (in-vehicle sensor, i guess it's called) or something like that. But when I get the chance I'm gonna run through the troubleshooting in that how-to so just making sure it will be the same for my '94.
Elazar
