Old 09-14-2002, 10:36 PM
Jamsvx's Avatar
Jamsvx Jamsvx is offline
Send a message via ICQ to Jamsvx Send a message via Yahoo to Jamsvx
Unhappy SVX shuts down midway through turn!
This afternoon, I was making a full lock turn in my SVX when the engine died, without warning, leaving all the warning lights illuminated...I turned it off and then restarted it and it was fine.
Needless to say, it has scared the wits of of money as I can imagine a giant monster from FHI creeping up on me, a monster that likes $$$$$$
Any thoughts? Thanks
James
1992 charcoal grey SVX:
27 August 2002 to 27 January 2004 - she will be missed
Was back in Sydney for a while but not hot enough so now in Dubai! Has it been that long since I owned SVX-33H!
Old 09-14-2002, 10:41 PM
Green1995SVX
My cavalier does this from time to time. My thought was that its because of the power steering pump needing too much "power" from the accessory pully, thus stalling the engine. Thats just my theory though, and it has always kept me happy.
Mike
Old 09-14-2002, 10:58 PM
Trevor's Avatar
Trevor Trevor is offline
Not the steering pump to be sure.
How much lateral force was being generated ! ? Could there have been enough to make something move and create a break in an electrical circuit ?
Possibly main battery connections, loose connector etc. Shove everything about that you can put your hands on with the engine running in an effort to duplicate the fault.
Trevor, New Zealand.
Boone
James,
Check your primary connections to the alternator and make a note to have it's function checked when you get service. Roasting a sacrifice to the SVX gods wouldn't hurt either. Boone
Old 09-15-2002, 12:14 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
Wink Doc, it hurts when I...
In addition...
I suppose if you were running close to empty and cornering hard, you may have starved the engine for fuel. That may be clutching at straws, but it is possible.
You may need to clean the throttle body as it has an 'idle up' motor that can plug up. If you were turning at full lock and foot off the gas, the potential for stalling is there. The p/s employs a pressure switch that signals the ECU to increase the idle when the pressure is running high, such as it will when at full lock. If the idle up passage is clogged it could stall. The same goes for your Cav, Mike.
Old 09-15-2002, 04:30 PM
oab_au oab_au is offline
Re: SVX shuts down midway through turn!
James
Ah that sinking feeling in the pit of the stomach, frustration as she asks "whats wrong James?" you reply "OH nothing dear" as you feel for the wallet.
I agree with Beav it is the idle control valve not responding quick enough, to pick up the idle speed to handle the pump load. Most likley a bit gummed up.
Keep smiling James.
One Arm Bloke.
Tell it like it is!
Old 09-15-2002, 09:19 PM
Jamsvx's Avatar
Thanks guys...I'll have to get it attended to. Is it expensive/urgent to address (I hardly drive the car...say 250km per week).
The car was 1/2 fuel of fuel (I think that is also inaccurate!! but seems to be the story with the 92's) and there was say 5% throttle was doing about 10kph.
At least I can be stressed out of my mind and clutching my wallet in the company of like-minded and like-suffering souls!
*raises glass to the SVX Stress and Spending Brigade....CHEERS*
Old 09-15-2002, 09:38 PM
Trevor's Avatar
It is interesting that you say that you had some throttle on and were therefore above idle.
Perhaps it would be wise to hold off spending money with some doubtfull
expert until you do some more trial runs and provide more details to Beav and Harvey.
Old 09-15-2002, 09:40 PM
Invisible avatar
Question
James - Did you try to do it again? I mean same speed, same road, same turn? If it won't die again, I suggest a gremlin was at work the first time. He's probably moved on by now.
Ron.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 09-15-2002, 11:02 PM
Boone
The cootie agrees.
Old 09-16-2002, 06:14 AM
Jamsvx's Avatar
Damn gremlins!! Probably one of those possessed Ompa-Lumpa's.....
I have not driven it since but will go back and try again this weekend - once I have the Auto Assistance (NRMA) paid up so they can come and get me if the gremlin brings its friends along!!
*crossing fingers*
James
Old 09-16-2002, 09:05 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
James
Dammit, James. I did *NOT* need that song stuck in my head today!
Ooompa, Looompa, doopity doo . . . . . ARGH!
Randy Johnson
Mike Davis -- at Reading VI
Old 09-16-2002, 09:24 AM
Green1995SVX
DAMNIT it just happened to me too!
Mike
Old 09-16-2002, 12:13 PM
vkykam's Avatar
vkykam vkykam is offline
The Road Less Traveled
James,
I remember a member who had a curious engine cutout while making left turns.
Then he found out his battery was not mounted down, and it slid and hit the cam sensor or something causing it.
Definitely reaching here...
Of course, maybe the car will prove to be problematic, and I WOULD be willing to take it off your hands if/when I decide to migrate back...
VK
Old 09-16-2002, 04:55 PM
Jamsvx's Avatar
Originally posted by vkykam
James,
VK
Thanks for the offer!!! Also for the suggestion - I will check the battery mounts!
*Ooomps Loomps dobbity doo, I've got a 4EAT tranny for you*
