Old 02-26-2009, 02:26 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Re: Project 1:10
This is just a theory, but I think the more weight you remove, the more acceleration/handling will improve.
You're partially right. acceleration will improve, hanlding will not improve unless it is done right. Much of the weight of the SVX is down low and centered. Removing low centered weight simply raises your center of gravity and ride height which is why the same SVX with an auto will outhandle the same SVX with a manual (assuming everything else remains the same).
Old 02-26-2009, 02:27 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Re: Project 1:10
Originally Posted by benebob View Post
17" are a waste of money for racing. You're paying for custom made stuff. 16s are cheap, lighter more durable unless you wanna look cool ridin' through the hood.
1/4 mile? Thank god you wear that body condom. We don't need anymore mullet heads around
So, you ready to sell the rims off of the RaceCar?
-Bill
p.s. problem I've had is finding 16" DOT tires that are wider than 275 (which I'm currently running).
Retired NASA Rocket Scientist
Center Network Member #989
Old 02-26-2009, 02:30 PM
benebob's Avatar
Re: Project 1:10
-Bill
Which is why you don't search for 16" DOT tires as real men use real race rubbers anyways, not sheepskin ponchos
Yeah I'll give you a good deal on the rims, $700 plus shipping! Another $75 for the lug nuts and lugs!
Old 02-26-2009, 02:50 PM
All else being equal, I think a 2700lb SVX will out-handle a 3600lb no matter where the center of gravity is, but my point was that was a ridiculous premise for destroying a car. "Gee, I wonder what will happen".
Old 02-26-2009, 02:57 PM
SVXRide's Avatar
Re: Project 1:10
Already have the lugs!
-Bill
Old 02-26-2009, 03:43 PM
boipeba boipeba is offline
Re: Project 1:10
Understand you idea, but knowing that that much steel is around me and the design of the car and its abilities in a crash allows me to sleep better. One of the reasons I bought the beast. Worth the increase in gas consumption.
good luck!
Old 02-26-2009, 03:44 PM
benebob's Avatar
Re: Project 1:10
-Bill
No you don't, not 30 degree lugs
Old 02-26-2009, 03:45 PM
benebob's Avatar
Re: Project 1:10
You shouldn't think too much then. I know we could have ours down to around 2500lbs wet but it would handle much like my f-250 does.
