ej22t wont run right
ok so i did a full rebuild on my ej22t and put ej20g dohc cams on it with 2.5l intake manifold..
i started the car today but it doesnt run right at all! it backfires within the manifold and my vacum level is about 5 at 1k rpm. i took off the #1 cylinder injector and it doesnt do anything to it running but it seems i could almost do that to any injector and it would still keep running with me giving it throttle.... my injectors were fine before the rebuild any ideas? |
Re: ej22t wont run right
every gasket replaced, new bearings... ect... full rebuild
pull off each plug wire until you find the one thats not firing/or each injector wire if you think its not getting fuel. how did you work the engine wiring harness to be compatible with your (stock turbo?) ECU?
Liberalism is a disease. When you can stare at facts and ignore them anyway, you have it. |
well is it misfiring or backfiring? Is there early detonation?. And something is not right if you didnt notice a difference when removing the injector :/. That means something inst detonating...
my coil pack is giving good spark on all cylinders. pulled each plug of the pack its self.
i can even run just the driver side cylinders n it will still stay started, it sounds like a max of 3 cylinders are going.. vacume should be near 20 not 5.. my intake makes a LOUD noise as if there is a fan in there. loudest noise from an intake ive ever heard. its definatly misfiring but its also backfiring because u can hear popping inside the manifold |
1994 SVX L - FWD Barcelona Red 190K miles ~ SOLD 1994 SVX LS - 5spd AWD Emerald Green 202k miles PWR Radiator, HID 5000k, New paint job with issues, 17" STI BBS wheels, converted to 5spd AWD from FWD. Purchased from SVXyGirl 2/20/09 -- Undergoing complete rebuild 1993 Justy 4wd 5door- Teal of sorts , beater. 2008 OBXT Newport Pearl 65k miles Last edited by Wikedjuggalo; 01-18-2009 at 12:45 AM. |
oh and real high revving, when it first started a few times it went to 4k rpm but now it goes to about 2500 or so at start up
Read the above post. I am pretty sure your answer lies in there.
yeh i read all of it, my t-belt is like 1 or 2 teeth off on all sides, will this cause it?
:/ yes... lol it very well can't help. try aligning them right. Did you read the part about sensors?
yeh ill make sure everything is 100% aligned tomorrow, yeh they said supposedly the plastic cams work with 2.2 sensor but wasnt confirmed. if the cam pulley is not the right cam will i still get spark?
you'll get spark but not right. it wont detonate right. Get the alignment right first and then see how it is.
do u know exactly the right cam gear i need in the sensor spot? all the cam gears were placed in a pile so they could be mis matched
not off the top of my head man but if you just grabbed two hoping they were right... lets hope nothing was messed up. Check your gears and lets hope you didnt miss match them
