Old 01-01-2009, 10:14 AM
gwomack's Avatar
gwomack gwomack is offline
Iris Check Valve
How do you know if it is good or bad? Is there a way to check it?
Old 01-01-2009, 11:42 AM
Re: Iris Check Valve
If you remove it from the engine, and can blow through it only one way it's good.
If it has a split or crack in it, it could still work, but at $21.00 or so from Subaru you should just replace it.
http://www.subaru-svx.net/photos/use...svxfiles|24710
