#61
Re: Gearshift Maps
ut oh, when you are done with that you are sure to get a request for the 2.0 turbo; they have the hitachi too.
#62
Re: Gearshift Maps
Yeah, Probably. Although I'm surprised the 2.0 turbo parameters aren't already posted on the net somewhere.
#63
Re: Gearshift Maps
i didn't mean 2.0 i meant 2.2
#64
Re: Gearshift Maps
Hey Michael,
I wonder if we're missing a trick with the TCU mods. Ryan's post on the USMB seems to suggest that on his TCU, the stock rom can be disabled by a resistor cut rather than removing it completely - like on our ECU. Quote:
Any ideas?
#65
Re: Gearshift Maps
r432 connects the oe of the surface mount to the same driver pin that goes to the dip socket
r431 if used connects the oe of the surface mount to high r430 connects the ce of the surface mount to ground (the ce of the dip socket is straight to ground) r428 connects the ce of the surface mount to high r429 pulls a14 of both pad sets high moving the resistor from r432 to r431 will put the surface mount in output dissable mode Quote:
Michael Emery, MBA, MS 94 SVX LSI, Ebony Pearl profile 94 SVX LSI, Ebony Pearl from back Performance and Multi-Fuel Tuning Last edited by longassname; 12-30-2008 at 09:33 PM. |
#66
Re: Gearshift Maps
I see it, the little green surface mount one in the corner with 000 stamped on it. However, it's a very small part for an amateur like me to solder. It might actually be easier to remove the rom from the board than to disable it by moving the resistor.
#67
Re: Gearshift Maps
http://www.alcyone.org.uk/ssm/tcumod.html
#68
Re: Gearshift Maps
sure,
I see you have a sst27sf256 in one of your pictures. Do you have a current source for them? |
#69
Re: Gearshift Maps
No. It's a sst27sf512. I got it from Calum. I think he got it from Mouser.
#70
Re: Gearshift Maps
ah, ya they still make those..the 256's are harder to find.
#71
Re: Gearshift Maps
subernatural,
Did you ever get a tcu? |
#72
Re: Gearshift Maps
phil,
if you come up with a desire to switch between tcu software on the fly I'll be happy to give you a multi-tune adaptor. |
#73
Re: Gearshift Maps
Thanks. I might take you up on that sometime.
#74
Re: Gearshift Maps
bump for this being cool..come on peeps..trust me, you want to chip your tcu.
#75
Re: Gearshift Maps
Im waiting on some funding lol. Like I said though, after my TCU is chipped I'll be getting a ROM off you.
1992 Liquid Silver/Black LSL LeveL10 Stage 3 Trans and associated stuff |
