#31
Re: Gearshift Maps
705404 is the 92 ROM isn't it? I don't think I'm finding the right file for the 94. I'll just read it again.
#32
Re: Gearshift Maps
I just use a 0.8 mm pin drill, to drill through the solder holes for the socket. Saves heating the board too much while you suck the solder out. ![]() Harvey.
#33
Re: Gearshift Maps
Solvent would be a better way to do it, but I didn't know at the time.
#34
Re: Gearshift Maps
Thanks for confirming the addresses. They match exactly with my list and the one from Tom's select monitor.
Yes. I just checked and your 705404 is the same as the one from Nomake Wan's 1992 car.
#35
Re: Gearshift Maps
Phil what are you doing with your shift maps? Do you have any engine work deserving of higher revs?
I'm a big fan of making the 2 to 1 shift come in with less throttle and raising the shift points/rev limits. I haven't really found anyting else in the shift maps I care to change. Even in a stock SVX I find changing the 2 to 1 downshift map a huge improvement though. I can't imagine anyone not wanting to. |
#36
Re: Gearshift Maps
What you suggest about the 2 to 1 downshift sounds interesting. I drive with the power button on nearly all the time. But I have noticed that when pulling away from a slow roll, it is often better to be in 2nd than 1st. The engine has plenty of torque available. Is that what you are talking about? I have done a mod for the UK models to change the econ mode switch to a power mode switch. A few people have that now but nobody has tested it yet. Other than that, I've been talking to a guy about doing one optimised for cars with the 4.44 or 4.11 diff swap. Somebody else is talking about swapping the internal gears in their box and wants a custom TCU for that. But I'm not working on either of these things yet. I am planning to do a version of the USDM TCU that doesn't require signals from the ECU. It can be used with the standalone ECU that Tom is working on. I do want to try the paddleshift code just to see it working. I wouldn't want to keep it on my car permanently.
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II Last edited by b3lha; 12-12-2008 at 05:06 PM. |
#37
Re: Gearshift Maps
Phil I perfer the shift maps on the JDM TCU. I found I drove most of the summer with the power switch turned on my JDM car. Really only switching to compare the two modes
I have done the power mod switch on my Canadian SVX and found while it is great in that it feels very sporty it holds each gear too long under lighter throttle. I find myself constantly turning power mod off and on. If I had a choice I would have JDM power as normal mode and USDM (Canadian) power mode mapping for the power mode switch. Peter
1992 (JDM) CXD Ebony Pearl 90K km written off hail damage 1996 (CDN) Lsi, Polo Green, 296,000 km 2009 Legacy Spec B |
#38
Re: Gearshift Maps
kind of,
I was mainly talking about the downshift of the normal mode map but yes I also like to change the normal mode upshift map into a kind of a hybrid betwen the normal and power mode map. Quote:
#39
Re: Gearshift Maps
Thanks to Phil
![]() Quote:
#40
Re: Gearshift Maps
Phil, did you notice full throttle shifts are off the rev limiter not the map?
#41
Re: Gearshift Maps
Do you think that copying the JDM maps to a USDM TCU will work well, or will the different final drive ratio have a negative effect?
#42
Re: Gearshift Maps
I don't think it would hurt anyone to try if they are curious. This is the kind of thing people can tinker with without worry of blowing anything up. I tighten up the endplay on the rotating assembly on my boxes when I build them and they can obviously hold a lot more torque but I don't have any problems running high rpms. I don't think it's an issue. Without the power mode mod the US model drives differently though since we switch from whatever mode we are in to power on heavy acceleration.
Here's the change I like for the USDM. Maybe you can plot this for us? power 1 to 2: 14 00 80 2B 16 B0 42 2C F0 53 00 F0 FF 00 FF normal 1 to 2: 0F 00 80 1E 33 C0 3C 19 F0 53 00 F0 FF 00 FF normal and power 2 to 1 0F 00 80 0F 00 C0 2D 19 F0 FF 00 FF |
#43
Re: Gearshift Maps
that's a 7600-7800 rpm shift at full throttle if you have your rev limiters set up (mine are at 7800) but if you don't raise your rev limiters you can use those same maps and your full throttle shifts will still be at 6500 rpms.
#44
Re: Gearshift Maps
Sure, I'll plot it Monday on my computer at work.
Do you know C programming? I wrote a program to pull the shift maps out of a TCU dump file and write a CSV file to import into Excel for plotting graphs. I can send it to you if you want it.
#45
Re: Gearshift Maps
Thanks,
Not so much. My schooling/experience is in object oriented programming (microsoft visual c#). I think I still have visual c++ installed from something else. I could run c stuff in that but it would probably easier for me/I'd be more comfortable just writing the functions in excell (I probably should have done that to begin with but I've been content wasting time making half ***ed plots on my worksheets). |
