Aftermarket engine parts forsale
Selling various aftermarket parts.
Forged Eagle Rods = $600.00 Forged CP 8.5:1 Pistons w/ rings = $1000.00 Custom Ground CAMS/Valves/Springs = $1500.00 ECUTune Stage 3 supercharger kit = $5500 (still needs to be removed from car)(includes) a. Whipple 1600x Supercharger b. Custom intake manifold c. Alternator relocation kit d. 300Z MAF e. 720cc injectors f. Belts g. Aluminum Pulleys h. ECU With code to run E-85 I dont have the time or money for my project anymore. Everything is up for sale. Pictures coming soon. Last edited by mikecg; 10-24-2008 at 09:22 AM. |
Re: Aftermarket engine parts forsale
Mike,
are you sure about the CR on those pistons? If they're the ECUTune pistons, I thought they were 8.5:1 -Bill
I'd have to call mike to make sure. You could be right. For some reason I had 6.5 stuck in my head.
yea, they are 8.5
Tom |
bippity bump
Bumpin it again. Make me offers.
Forged CP 6.5:1 Pistons w/ rings = $1000.00 Custom Ground CAMS/Valves/Springs = $1500.00 I'm sorry, not exactly the post to write this in, but explain me the 'built' concept here (btw, I am in the price market here). Are these needed, or important, for the super charger? What exactly are the pros/cons of each? I'm sorry for my ignorance. I think there are probably others who don't know either, but have the cash, and might be convinced, if its explained. James
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN! |
You don't need the pistons,Cams and rods for the supercharger kit. Currently the kit is installed on my car running 9lbs of boost. However, that is the max the factory engine can handle without risking damaging it. The rods and pistons are much stronger than the factory ones. The cams and valves will allow for better flow and increase power.Lowering the compression ratio with the aftermarket pistons also allows you to increase the amount of boost you can run the supercharger at. this will increase the amount of fuel and air you can put into the engine increasing power. My plan was to put together an engine using the new parts and put it into my car. After that I was going to increase the boost of the supercharger from 9lbs to 15lbs and also add a NOS kit. All that said, you could just by the supercharger kit alone and not worry about the rest. The CAMS and valves can be used by them selves also, however if you loose the timimg belt while running them they will get damaged. The rods and pistons I'd recommend using together, however the lowered compression ratio means that the are designed to be used in a boost application. If your not going to use a supercharger or turbo these pistons are not for you. I hope that helps. If you want anymore information please feel free to contact me. Also, all the parts listed here I got from ECUTune.com.
Actually interestingly enough, I did install the cams and valves but not the pistons and through the timing belt due to a pulley bolt that was torqued wrong. But to the important part. The valves came out of it fine.
From talking to Mike at ECUTune, you got really lucky. There isnt alot of clearance with the new CAM profiles and valve lengths.
What are the specs on the cams and valves? Are the cams re-grinds, valves swirl polished and undercut? And finally are they designed for turbo or super charger applications.
You should be able to find the specs in the old Cam thread. Dustin
-Dustin 1992 Ebony LS-L w/191k miles Mods: a few ![]() ![]() ![]() 1995 Brilliant Red L/AWD w/154k miles Mods: Stebro catback exhaust, K&N drop in filter, ECUtune ST1v5, 4.44, lots of JDM goodies 1992 Pearly LS-L w/154k miles Sold ![]() 2008 DGM Legacy spec.B w/245k miles Mods: Cryotune Stage3, VF52, bushings galore, STi pink springs, Bilstein HDs My Locker The only man alive who drives three "Subu SVS's".......according to my insurance company |
do you still have these?? how many miles were put on them after being installed? or were they installed???
Mike, just letme know if you'd be interested in this, but any chance you'dbe up for parting out all the stuff for 2v7? So, injectors, MAF, computer... Um, just curious, if you don't want to I understand, but I figure it never hurts to ask!
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! |
I think Mike died... jk but i'd really love see about the parts....
