Old 10-07-2008, 11:39 AM
Manarius's Avatar
Manarius Manarius is offline
Re: WTF is wrong now........
Originally Posted by SVX92-97 View Post
Hmmmmmmmm! Why not go to your local carwash and wash the engine down. Works for me everytime on my legacy with leaky valve cover gaskets.
That stops smoke from inside the engine bay. That video is smoke from the exhaust which means that some oil (perhaps got into the cylinder and burned.
Maybe it was just some gas that laid in the cylinder for a while. Like everyone else has said, if it doesn't came back for a while, maybe it was just a fluke.
-Jason
-Obi Wan Kenobi
Old 10-07-2008, 04:16 PM
oab_au oab_au is offline
Valve guides and seals don't start leaking "suddenly", it is a very gradually process.
It is more likely that the oil has come from the inlet manifold, through the crankcase ventilation system.
One Arm Bloke.
Tell it like it is!
Old 10-07-2008, 04:23 PM
mysvxrocks's Avatar
mysvxrocks mysvxrocks is offline
Im REALLY addicted! CANT STOP!
Send a message via MSN to mysvxrocks Send a message via Yahoo to mysvxrocks
I washed the engine off after I resealed the valve covers, though it is STILL smoking under the hood. Something is still dripping onto the passenger exhaust. Whatever, it smokes it smokes. I cant dump anymore money into it at this point. The exhaust smoke is still there, it did it again thismorning. Seems like it only does it after sitting all night. Hopefully it will go away.
D.J. McPhee
2006 Infra-Red Ford Focus ZX3 ~ 67k
No longer SVX'n, Ill always miss them!
1995 Polo Green LS-i ~ 95k
1992 Dark Teal LS-L ~ 145k (04/91) #2231
Old 10-07-2008, 10:21 PM
Turbone Turbone is offline
Banned
Send a message via ICQ to Turbone Send a message via AIM to Turbone Send a message via Yahoo to Turbone Send a message via Skype™ to Turbone
Maybe we can take a look at it this Sat up in Leavenworth.
Old 10-09-2008, 06:05 PM
mysvxrocks's Avatar
So, Ive been switching up which SVX I drive, and today I decided to drive my 92. It seems so much smoother steering wise... a lot eaiser than my 95. So after school today, I decided to investigate. Checked the fluid level of the power steering, and it was way over filled. So I took out quite a bit of it, and also changed the belt. Started the car, and noticed pretty quick that its running quieter. The steering also seems smoother. So I drove it around for a little bit, making some hard turns, and I noticed something else. The binding that I was feeling, seems to be gone. It would always do it when pulling into my parking space, and this time it didnt. I pulled in 3 or 4 times and it didnt do it at all. Could having too much fluid cause the car to shake when turning/accelerating? If so, then I seemed to have fixed that issue.
Also, the car is still smoking, but after I started it today (it had sat for about 18 hours) There wasnt as much. Its still there, and I can smell it, but not as bad. I checked the oil, and its actually a little over the full mark as well. Could that cause it to smoke like that? Its not over filled by a lot, maybe 1/4 inch over the F mark on the dipstick. Should I drain some of it out?
-Dennis
D.J. McPhee
Old 10-09-2008, 06:43 PM
Uncamitzi's Avatar
Uncamitzi Uncamitzi is offline
Member #447
Send a message via MSN to Uncamitzi Send a message via Yahoo to Uncamitzi Send a message via Skype™ to Uncamitzi
just a quick question and comment about this.. are you using ATF in the steering or Steering fluid... it's designed for ATF... I used Steering wheel fluid once.. it screwed up my seals and made the pump run badly (binding and chugging) cleaned everything out and put the ATF back in and all was fine...
I've been driving Subaru since 1976... valve guides are almost always the culprit on the smoke that I saw in your video.. watch your level.. drive normally and you can drive a long time before it becomes too bad to drive. eventually you will need to replace the seals.. but you won't kill your engine unless you let the oil get too low...
it more than likely didn't "Just start"... it probably has been doing this gradually for a while... but.. that big puff of white smoke that you just noticed is always a surprise..
Have fun and don't despair
Mitch Hansen
"uncamitzi"
This is a Dark Ride
92 Teal SVX LS-L 128K tranny swap with 4.11's
Well.. my days of not taking you seriously have certainly come to a middle .
Old 10-09-2008, 07:14 PM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
you know, its ironic that you mention all this
just recently i had noticed smoke coming from my engine bay (not from the exhausts) and i couldnt tell for the longest time where it was coming from
then i finally saw there was some ATF on the passenger side exhaust
took it to a car wash and cleaned and power washed that section of the engine tonight.
anyway, a few weeks ago i needed to refill my power steering fluid (was hearing groaning noises when i steered), so i did
and the week after that is when i noticed the smoke
im just wondering, where is the ATF that was dripping onto the exhaust coming from?
would that be the power steering?
because the exhaust (pass. side) isn't exactly under the power steering resevoir
im assuming that you had the power steering ATF on your passenger exhaust, but i guess the main question is, how does it get there?
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
Old 10-11-2008, 08:58 PM
mysvxrocks's Avatar
Alright, so shes smoking, a lot. This time, from the engine. Exhaust too, but one thing at a time. So I pulled into the gas station after I got home from the Fall Colors meet, and smoked out everyone else at the gas station...
So, there is fresh oil covering the crossmember, and dripping from there, dripping from the oil pan, and dripping from the transmission. Its smoking on both sides. Is that a symptom of the rear main seal?
D.J. McPhee
Old 10-12-2008, 12:26 AM
Rear main seal, seperater cover, or t/c seal... Are you sure it is engine oil???
Old 10-12-2008, 10:49 AM
It could be coming from the PS pressure line. I have that problem right now with one of my cars.
Old 10-12-2008, 11:49 AM
mysvxrocks's Avatar
I think thats what it is... What else could it be? There is a gaining puddle on the ground of whatever it is. Its dark in color, brown. So I assumed oil.
D.J. McPhee
Old 10-12-2008, 11:59 AM
The oil in the puddle yesterday was engine oil.
Old 10-12-2008, 12:19 PM
mysvxrocks's Avatar
Agreed. I just replaced mine as well.
D.J. McPhee
Old 10-12-2008, 04:38 PM
Keoni's Avatar
Keoni Keoni is offline
man dennis, i know how you feel, my svx is smoking too. but mine is coolant from the heater hose. I agree that someone who drives an svx needs a back up car as well. Not a car for a poor college student like myself.
Old 10-13-2008, 08:21 AM
mysvxrocks's Avatar
You and me both. And Ive got two of them!
D.J. McPhee
