Is this a normal MAF malfunction
I'm driving doing about 40mph, then all of the sudden the car looses power and stalls out while I'm still going at that speed....I've never had that happen before...so I put it in Neutral and started it up while moving.
I read the code and got a 23 so that means MAF, but can someone tell me that this is normal or is this something bigger that could be the problem? WHy would a bad MAF cause stalling? I'm not sure what it's supposed to do actually. Can someone explain? |
Re: Is this a normal MAF malfunction
I never had my car go to the extreme of stalling while driving, but when the MAF went bad on my ebony a little while ago it would cut out at highway speeds, felt like it would all of a sudden lose power then all would be fine again after a few seconds.
1992 Subaru SVX 5spd 1998 Pontiac Firebird Formula 1999 Chevrolet Camaro SS 2009 Subaru Forester - Mileage Junky 2009 Pontiac G8 GT 2017 Ford Mustang GT 6spd |
Mine would stall completely like that. usually it would start right back up, sometimes I had to wait a minute...
...i dont know why , i suppose maf calculate air flow + fuel , no air no fuel ?
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008" rest in pieces Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill |
Ok, I'm getting a used one soon in the mail...but I did spray the current one with brake cleaner (no residue)...the only thing I didn't do was cut the gasket to look inside...I hope the used one works.
when my car was stalling it gave me the effect it would be worse on hot sunny days , during night or cooler days it wasn't doing it ....
The MAF meters incoming air volume in cubic feet per minute usually, and tells the ECU exactly how much fuel to add. Sometimes a leaf or some dust or other foriegn debris can get stuck in the vane and cause a wierd reading, stalling you out. Id also check for a loose or corroded connection on your harness that plugs into it before dropping the cash for a new one, they arent cheap. Cant hurt to try!!
mine did the exact same thing when the maf died it would run sometimes then all of a sudden just let the car die it would normally start up right away but was a fickle fix, when replaced it hasnt done it since. my opinion replace with a good WORKING maf and should fix the problem as I read it
William |
The harness looks ok, not corroded or anything. Yes those parts are expensive, must be the circuitry inside causing the high price.
The main question since I havent disassembled mine is if the MAF is the air vane type or the swingdoor type. Swingdoors tend to wear out and lose resistance values at some particular point along the contact arc (earlier toyota EFI's had this problem), but vane type are pretty solid-state, and dont normally wear out. I cant really tell for sure by looking at mine but if your SVX isnt a daily driver it cant hurt to monkey around with it anyways and maybe see if some foreign debris could be in there.
I opened up the MAF and all the soldered connections are there...can it be the copper cover needs to be resoldered? I can't think of any other obvious defect..
