Bad o2 make the car earthquake shake?
So after riding around for an hour or so.... the SVX sits parked for about 35 minutes while I go into the store. I come out, start it up and the entire car is shaking really really bad. chug chug chug chug chug....
Great... so finally the light comes up and the code gives me 32 - oxygen sensor... yet it seems like a spark plug is misfiring? Should I just go ahead and replace the o2 sensors and then take it from there? Also, after driving it home (9 miles) I pulled the codes again then it gave me 32 and 56. Would the o2 sensor and driving on a bad one result in the code 56 maybe? I don't see anything wrong with the exhaust or anything else so I dunno? Thanks for any input.... I've had the new radiator installed for a day, happy to be driving it again and then this pops up.... meh.
1994 subaru svx le 112k |
Re: Bad o2 make the car earthquake shake?
That's the plan... but in the meantime my mind is still in wonder as to if this is actually the root cause and would make the car run that badly...
Read here :P If the problem repeats start with EGR valve then move to O2 Sensor it shouldn't cause it to shake like that.
Thanks for the link!
1994 subaru svx le 112k Last edited by Subix; 08-04-2008 at 06:17 PM. Reason: e |
I would do the EGR first Would also make sure the timing belt hasn't slipped.
Keith ![]() Last edited by kwren; 08-04-2008 at 07:28 PM. |
^^ THat is what I suggested :P Reading back now it might have came off as confusing.
I am running around like a chicken with it's head cut off and didn't have time to read the stuff! Take care, Keith ![]() |
as suggested, check the egr valve to be sure it is closing... You could simply just reach under while the car is running and try to move the valve with your finger to see if it changes the car's idle.
Tom |
Yes, it feels like a plug is fouling to me.
The Worm ![]() _______________ June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod" Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012 '05 Infinity G35 Coupe. No Mods, 33K Miles |
Where is the general location/area of the EGR? ![]()
might look under the intake manifold. I think it might be there. Pretty sure
It is actually under the main wiring loom on the rear passenger side of the engine.
Tom |
Always wondered where that rascal is! Appreciated, Keith ![]() |
