Old 07-27-2008, 04:18 PM
jrobe jrobe is offline
How do I get the rubber cam plugs out???
I'm trying to get the upper cam plugs out. Do they screw out or pry out?
What kind of seal is behind it?
Thanks Jeff
Old 07-27-2008, 05:24 PM
kwren's Avatar
kwren kwren is offline
Re: How do I get the rubber cam plugs out???
just pry them out if you have a new one, look at it!
has a lip on it just pry the lip out and out it comes.
(almost a wonder that they stay in)
There you go...
Keith
kwren's Avatar
Thanks Jeff
it is the seal!
Old 07-27-2008, 05:37 PM
I think mine might be leaking. Can I just pop them out and put a thin coat of RTV on it and pop them back in?
Old 07-27-2008, 06:08 PM
dromano's Avatar
dromano dromano is offline
After enough age the cam plugs lose their ability to seal the end of the cam. Put in new plugs, $12+ at Subaruparts.com + s&h.
I am about to change mine (hurry up DHL!!!) the drivers side is leaking, the passenger side is dry, changing it anyway. Changed the crank/oil pump seal today, that seal was a job to get out.
Is the oil pump O ring the one at the lower passenger side of the oil passages?
It's about the dia. of a quarter.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 07-27-2008, 06:42 PM
The oil pump oring is the only oring when you take off the oil pump. All of the ones I have seen are blue. It is on the lower left.
I wanted to get mine back together tonight, so i'll try the rtv.
Old 07-27-2008, 10:53 PM
SUBBYRU89's Avatar
SUBBYRU89 SUBBYRU89 is offline
Siren of the Pleiades
Send a message via AIM to SUBBYRU89
Yeah, I've done that without any problems.
14.708 in the 1/4 mile pre-KillerWail
'89 XT6 Pearl White~JuiceBox (Project)
'92 SVX BoverP~Peej (Down for the moment) 1st Stage II trans installed by AWD,15 & 20 min mods,...
Old 07-28-2008, 05:02 AM
dromano's Avatar
How long(time)/many miles have the plugs with rtv sealed?
Old 07-28-2008, 11:22 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
That was me responding on Subbyru's computer...
I probably had them in place for about a year with no problems for about a year before I had to pull the engine apart for a head gasket job. When I did the HG's I used new plugs.
Old 07-30-2008, 11:49 AM
dromano's Avatar
Here's a "heads up" for you, the passenger side is the "right" side, "left" is driver side. I know when you look at the front of the engine that O ring is on the left, but that's the right side. This is how the SM describe the sides, so if you're standing in front of the engine the left is on the right
Old 07-30-2008, 02:40 PM
kwren's Avatar
Sort of reminds you of the old country song... "I'm my own Grandpa"
Keith
Old 07-30-2008, 05:28 PM
Hocrest's Avatar
Anything on a car referred to as right or left should be describing the position as it relates to you sitting in the drivers seat.
That's why it seems backwards when you're looking at it from the front of the car.
Old 07-30-2008, 07:12 PM
dromano's Avatar
Tried to say that
Old 08-02-2008, 08:47 PM
dromano's Avatar
How did you remove the cam plugs without damaging them? I drilled a hole near the center of the plugs and would describe the removal as not an easy task. How did you remove them without damaging them?
My plugs had grey RTV on them. Is this a normal Subaru procedure?
Old 08-02-2008, 10:05 PM
kwren's Avatar
If I had to take the cam plugs out, I would always put new ones in
Good luck with your project
Keith
