02 sensor question
What could cause a 37 code 02 sensor fault when it is not bad?
Thanks, Keith ![]() |
Re: 02 sensor question
Oil on the o2 sensors
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress |
TY! will check Keeping fingers crossed...
Appreciate the info Keith ![]() |
how do you know its not bad??
Tom |
Could be bad
I replaced it less than 4 months ago. I am getting another but wanted to check the other possibilities. Replaced with a Bosch. If there is an oil problem could it be cleaned and could the oil be inside the exhaust system or outside the pipe where the wires fasten in? Thanks, Keith |
Oil dripping onto the wires from the motor leaking oil. Mine throws a code for both but i have no change in MPG, hesitation, or other reasons but i'm replaceing them anyway because I suspect that they have never been changed since the car was new.
Mine does stutter some of the time and the "Ck Eng" lite comes on and I check and get the code 37 I did have a bad oil leak on that side. Fixed that now the 02 ![]() Thanks again |
My CEL came on once in a while then i checked the ecu and found both but no symptoms.
Could running regular gasoline to save a buck make the car run stupid??
Keith ![]() |
yes... you will ping and and the o2 can also read as lean causing your code...
buy the gas it is worth it. unless you can have the chip and be tuned for regular gas. |
Honestly, in order to monitor the 02 sensor to actually see if it is working properly you should try and find someone with a subaru select monitor. This will show you the reading the sensor is picking up. Easier way to check the sensor is to switch them around from side to side to see if the code follows it.
![]() Tom |
Thanks Tom!
I was considering the switch and may do it yet! I have been replacing fuel with high octane for several fill ups and it is doing better. I can go a while on the freeway now with almost no bad results but then it will start like a little rough and the check engine light comes on. This always shows a code 37. When the slight missing occurs, I have started droping the trany down to 3rd and petal to the metal and the check engine light usually goes off and then runs smooth again. Last night I toped the tank off again with about 9 gallons and drove home... about 25 miles pretty smooth and when got home the idle was also good! Will see what the 100+ miles do taday and go from there. Thanks for the input!! Keith ![]() |
Keith,
The times I put 87 octane in, the engine would let me know, usually before reaching running temperature, lots of little pauses and little jerks, just telling me how stupid being cheap is. ![]()
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited 2012 Outback 3.6R Limited! ![]() |
Highest octane I can get from now on. Probably even get a bit better mileage that way to ofset the cost. I haven't gotten to clear the code 37 for weeks and I replaced the 02 sensor today and they cleared. Sounds like Tom was right! How do I know it wasn't bad? I had replaced it only 4 months ago and thought the code not correct. Curious as to why it went bad so quickly. Well hope it is over for a while. Take care everyone... Keith ![]() |
