Old 07-14-2008, 08:03 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Re: Baseline Dyno 7/16/08
I imagine you would have broken 200whp if you had a 5 speed instead of a 6 speed, correct?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 07-14-2008, 10:08 AM
Originally Posted by SVXRide View Post
Yeah, your "custom exhaust" includes hand fabricated equal length headers (remind me of their ID and length?)
-Bill
Bill, 1.75OD on the primaries... Too big for an N/A car... I probably would have been over 200 wheel if the exhaust wasn't built for an engine twice this size.
Tim, that may be true but I cannot say yes without being skeptical.
Old 07-14-2008, 11:21 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Yeah, that's what my memory was telling me Want to PM me the length of the primaries?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-14-2008, 11:26 AM
They are between 32-34" with more ground clearance in mind on this set it would have been near impossible to make them any closer in length.
BTW here's the sheet
tom
Old 07-14-2008, 11:32 AM
JaySVX's Avatar
JaySVX JaySVX is offline
Nice numbers! I am interested in seeing where this one goes.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 07-14-2008, 11:42 AM
using 27% loss in the driveline rough math puts it about 260 at the crank.
Old 07-14-2008, 01:44 PM
SVXRide's Avatar
YT,
Can you get SAE corrected plots? Most of the data in my dyno database have this correction. What gear did you do all of the pulls in?
Thanks.
-Bill
Old 07-14-2008, 03:14 PM
YT,
Thanks.
-Bill
4th gear on my v.8 jdm 6spd. I cannot get the plots... they did 120 pulls on 40 cars that day... So what I have is all that I can get
Old 07-15-2008, 11:08 AM
RallyBob's Avatar
RallyBob RallyBob is offline
Registered fabricator
Maybe in your current state of tune, but if you eventually are pushing for more N/A power I think you're okay.
Jack's car runs 32" long 1.75" primaries, and while I honestly thought they were too big initially (we were eventually planning forced induction when I built them), they ended up working quite nicely with our modified high rpm N/A setup.
Bob Légère
EG33 Impreza tweaks
Old 07-15-2008, 12:18 PM
Understood... but I built them in mind for my s/c along with the very large and heavy 2.5" true dual behind them... I am happy with where the car is at... Very consistent and w/o any issues. This means I have a great base to work from... Now I await the ever so important email
Old 07-15-2008, 07:27 PM
vlmaclean vlmaclean is offline
Banned
tom
I found this very interesting. I was thinking the 6 could do more with mods. A modded RS 2.5L is putting down the same power here:
http://www.rs25.com/forums/showthrea...2dyno+chart%22
Old 07-15-2008, 08:02 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
The same peak perhaps, but the 2.5L is not nearly "the same" until ~6000 RPM.
Peak power stands for little in my book. It's all about the area under the curve.
Old 07-16-2008, 09:50 AM
This is also a baseline... this engine has completely stock internals. If you want to look at an N/A build RallyBob has put together an EG33 RS making 290 at the wheels.
Old 07-17-2008, 07:23 AM
Myxalplyx's Avatar
Myxalplyx Myxalplyx is offline
XT6 is SVX's Daddy
Send a message via ICQ to Myxalplyx Send a message via AIM to Myxalplyx Send a message via Yahoo to Myxalplyx
Nice numbers Tom!
Better to compare other cars that have dyno'd on the same dyno. Area under the curve is all good but just remember there are other variables to consider as well. Sure an RS making the same peak with less hp/torque under the curve can appear to be slower all around but if it is lighter (depending on how much lighter), it could blow away an SVX with a better 'area under the curve'. Or two SVX's making the same hp/torque and the same weight but one has lighter weight wheels and junk-inside-the-trunk vs one with heavier wheels and no junk inside. And the variables go on......
Looking forward to seeing how things turn out Tom. A friendly race or two at the track would be nice. ***Heading back into the shadows***
Kevin Thomas
1997 2.2ltr Subaru Impreza Outback Sport Wagon (AWD/Auto) 13.03@100mph
1989 2.7ltr Subaru XT6 (AWD/Auto) 15.912@85.93mph
1996 3.3ltr SVX (AWD/Auto) 15.070@91.38mph
***R.I.P***
2010 RAV4 AWD Sport (13.717 @ 99.19mph )
2015 Honda Fit LX CVT (15.2 @ 90mph)
Old 07-17-2008, 09:03 AM
not charts but here are some numbers from others running the same day...
