Old 05-08-2008, 08:14 AM
CorSVXette's Avatar
CorSVXette CorSVXette is offline
SVX- My daily driving Corvette
Send a message via AIM to CorSVXette
Classic SVX
ABS Light
Started my car this morning and the ABS light is on. Any ideas as to why and how to fix? Thanks.
Paul
1969 Corvette
1995 SVX L Safety Option Package, HID's & Awsome Braking (Svxfilies/TomsSVX), JDM Clear Corners, JDM Boxer Engine cover, Transmission Cooler, AND NOW JDM FOLDING MIRRORS!
1995 Corolla
2003 Highlander
Old 05-08-2008, 08:19 AM
Is the abs still functioning? Are your brakes working as normal? Any pulsations when stopped at a light?
There could be several different causes for this:
1. ABS Relays in the under-hood module at the right front
2. ABS circuit in the fuse panel
3. Faulty Wheel Sensor
4. Broken wire to wheel sensor
5. Faulty ABS Computer
Given the circumstance as described, I would try troubleshooting the simple aspects of it first (fuses and relays), rather than going through the replacement of a sensor right away.
Old 05-08-2008, 08:24 AM
CorSVXette's Avatar
Classic SVX
Brakes appear to be working normaly. I did not try to slam on the brakes to see if they are working. I guess that would have been a good place to start
Paul
1969 Corvette
1995 Corolla
2003 Highlander
Old 05-08-2008, 08:27 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Check the ABS error code to see what it is complaining about.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 05-08-2008, 08:58 AM
d'oh. I forgot to mention that, its that sort of first thing to do.
Old 05-08-2008, 09:04 AM
CorSVXette's Avatar
Classic SVX
How do I check the ABS code? Can I do it with my Select Monitor?
Paul
1969 Corvette
1995 Corolla
2003 Highlander
Old 05-08-2008, 09:10 AM
b3lha's Avatar
Phil & Belha
No.
Instructions on this site: http://www.svx-iw.com/
Old 05-08-2008, 09:46 AM
CorSVXette's Avatar
Classic SVX
Thanks for the info.
Paul
1969 Corvette
1995 Corolla
2003 Highlander
Old 05-08-2008, 03:07 PM
CorSVXette's Avatar
Classic SVX
OK, Just started the car for the ride home from work and the light did not come on and stayed off the whole ride home. Is this something I should be worried about?
Paul
1969 Corvette
1995 Corolla
2003 Highlander
Old 05-08-2008, 04:27 PM
Hocrest's Avatar
Hocrest Hocrest is online now
Freezepop's are Awesome!!!!
Check the codes, then you'll know if you have to worry...
Old 05-09-2008, 03:45 AM
CorSVXette's Avatar
Classic SVX
Yea, but according to the information on how-to check the codes, the ABS warning light needs to come on. Since it did not come on I cannot check the codes. I guess I will just have to wait till it pops on again. Thanks for all the help.
Paul
1969 Corvette
1995 Corolla
2003 Highlander
Old 05-09-2008, 08:38 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
The ABS light also comes on if one of the yellow connectors are loose. One of them is under the kick plate. Move it and see if the ABS light comes back on.
Old 05-09-2008, 08:43 PM
Hocrest's Avatar
The yellow connectors are for the Airbag system.
Old 05-12-2008, 08:04 PM
dannmarr's Avatar
I work for my SVX
Thanks for the correction, I got mixed up, sorry.
Old 05-31-2008, 11:09 AM
racecube racecube is offline
I think it's a common problem: Remove the plastic cap with the ABS sticker on it and you will see a relais (don't know if it's the english word). Pull it out and knock it sometimes on a hard surface, then put it back in the holder. It will work again and the ABS lamp will go out. This will really help!!
Excuse for bad english cause i'm from Europe.
greets Eddy
