#181
Plenum chopped, enlarged, and re-welded!
While I have had no time to work on this project personally, I spoke with Jack about it, and he had XXTuning's current fabricator (Sean) modify the stock intake per our discussions. What this means is the entire center plenum area is basically open, the IRIS is gone altogether, and the manifold lost 7 lbs of weight too! The forward-facing 'wall' area is curved to direct air to each runner side, but other than that the entire plenum is a huge box now. Plenum area has been basically tripled compared to stock. I sort of like the 'consultant' aspect of this for me...I didn't need to get my hands dirty at all! ![]() He didn't make the plenum area 'adjustable' like I had originally hoped (I sometimes tend to complicate things by making them overly adjustable), but I think we're likely to see a significant change, good or bad. |
#182
Bob,
Cool! Any pics of the final version? Did Sean end up shortening the "legs" of the intake in the process of making the "body" bigger? -Bill p.s. the EG33R pics you've posted are great! Any chance you can add pics of how the steering quickener was added in?
#183
I have a new camera, but with no software to be able to upload new pics...sort of useless actually. I tried to take video of the quickener install a few weeks back. It is virtually unseeable once installed, I couldn't even get my camera into the space unde the dash. It literally is completely hidden from view in the car. It simply entailed shortening the steering column itself, and installed the quickener in the column prior to the firewall via splined and welded couplers. A bracket welded to the outer column's steel shell secures the quickener body in place so the body itself can't rotate. |
#184
A tiny update.
The customized large-plenum intake manifold has been test-fitted and the engine run. No tuning or dyno time was performed, as an interesting dilemna showed itself. When the throttle is blipped, the plenum top and bottom plate (.125" 5052 aluminum) gets sucked inwards by almost 1/2". I don't really see how a piece of (roughly) 10" x 10" aluminum plate that's .125" thick bends so much, but it un-nerved Jack enough that he removed the intake and never bothered to dyno the car for fear of cracking the intake @ the welds and sucking broken-off material into the engine. So the intake plenum will have to be revised somewhat, probably with some centrally located supports welded in place. Then it will get dynoed. I think it will be promising. I'm almost thinking this is showing that the twin TB's are restricting the flow to the intake, although that is admittedly a bit tough to fathom as they're pretty darn big. But then again I have nothing else to compare it to...I have never run another EG33 with cams and headwork so I can't really comment on the VE potential of this engine when all the mods are in place. Another interesting side effect is the induction noise at idle is now significant. You can truly hear the camshaft overlap pulses inside the plenum. I guess the stock plenum divider wall significantly dampened the pulses previously. I'm open to comments and input from other forum members. |
#185
I don't have any comments other than I hope you are keeping track of everything you are doing. Because as soon as I have the $$$ I'm coming to you for a mild build on my engine!! ![]() ~ Chris
2020 Subaru Outback Touring - Wife's first Subaru 2005 Volvo V70R - 5-cylinder love! :Heart: ** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned ** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!! ** SOLD ** ![]() |
#186
![]() Keep us updated Tom |
#187
![]() The engine will achieve a VE of 106%, in its standard state, at higher rpms it will achieve 110%. Harvey. ![]()
#188
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
#189
Saw Jack and his car at at Pocono today. Said he had dynoed the car at 300whp recently. Also said he is still having some overheating problems, despite having a 25 psi radiator cap. He confirmed that he is going for individual throttle bodies for each cylinder.
I also found out that a 20 psi radiator cap is incompatible with the stock radiator. More about that unfortunate discovery when I report on my track day at Pocono later this week.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
#190
![]() ![]() ![]() ![]() -Bill
#191
yea he split the tank at their usual weak spot on the top. No worries an all aluminum PWR is on the way for his ol' girl
![]() Tom |
#193
#194
Rally Bob:
Jack's car sounded great. I don't think I was on the track with him because I was in the Open Track sessions and I think he was in the Comp School. I couldn't get a ride because it's now a "proper race car" with only one seat. Yes radiator split along the front side top between the hose connection and the cap nipple. Tried to KDWeld it, which lasted about 5 miles. Towed to Ertle Subaru in Stroudsberg. YT is UPS'ing up to their shop the radiator from his silver, which is down, and I'm buying a new one that will ulimately go back in the silver. They said they could install, but no warranty. I told them, "It's a track car, I'm just as likely to ask you for a waranty as I am to ask my insurance company for damage protection on the track." Hopefully, I can pick it up on Saturday morning and drop by Reading on the way home. Obviously Lime Rock is out for that morning.
#195
