Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Transmission and Drivetrain
Old 03-06-2008, 03:09 AM
Dessertrunner's Avatar
Took the 6 speed out to get check.
As I mentioned before I had to take the 6 speed out to reset the diff because I stuffed it up when I put the seals in. I also want them to check for a clicking noise that I can some times hear when the car is in netural. Turns out that there is a circlip on the syniro rings that comes lose. I will let you know when they tell me tomorrow whats wrong.
Tony
Old 03-06-2008, 06:23 PM
We have discovered that the DCCD is burnt out. So I need to get my hands on a kit to service it. Does anyone know were I would get one as they don't sell them in Oz.
Old 03-06-2008, 07:03 PM
no I don't... Didn't know they had service kits for them.. I thought it was a replace the center diff fix
Old 03-06-2008, 08:21 PM
As I understand it Tom you can get a overhaul kit because the rally guys burn them out all the time. I will let you know when I find out were to get it, I am onto Mychailo as he has contacts in Japan. I think this is the part number.
390004S020
Tony
Old 03-06-2008, 09:27 PM
AGREENTREEFROG's Avatar
AGREENTREEFROG AGREENTREEFROG is offline
TREEFROG
Part Number
390004S020
Tony
ST390004S020
Old 03-06-2008, 11:43 PM
It looks like the DCCD unit is okay, it must be that it gets hot as part of its operation. I have pulled the unit apart and all the clutch plates and the ball bearings are good. So in it goes again.
Tony
Old 03-07-2008, 06:19 AM
Well if the DCCD is not working properly... You need to fix it... Do you have a controller hooked up?? what is it?? I have heard of some A/M controller burning out the coil
Old 03-07-2008, 11:38 AM
My problem is I don't have a controller and when the wheels spin it generates heat and thats why it gave the apearance of being burnt out but was okay.
I was planning to buy a controller from Spider from what I can gather they are okay. Do you know what his are like?
Old 03-08-2008, 04:50 PM
dynomatt dynomatt is offline
Tony, what gearbox did you end up with? What's the code?
Old 03-08-2008, 07:23 PM
Matt here is the number.
the code on the box is TY856WB3KA
Its all good we will put it back together tomorrow I just need to make sure that I have the DCCD in the lock position when on sand etc so I don't heat it up to much.
Tony
Old 03-09-2008, 10:16 AM
spider's stuff is good. Good luck with it
TOm
