#46
so wait i'm confused what's this about dremeling stuff i thought u just used the stained glass paint to change all those buttons to red??? couldn't i do the same with blue???
#47
Yes you use the stained glass paint. But the white letters/symbols on the buttons have a green tint to them on the reverse side(inside when assembled). He is talking about using the 180grit to get that green tint off.
bLAh
#48
the buttons (fog,cruise) those buttons all you do is glob some stained glass paint on the back side of them the back of the buttons are white so any color will pop! i used the 180 grit behind the hvac display with a quick swipe over the green so the stained glass paint will stick to it a little better
#49
I’m just picky. I not only wanted it blue, I wanted to SEE it and be crisp. You could call it overkill, but it was necessity to me.
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts -
![]() [SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not ![]() Member #995 ![]() Catch you next at: ? Auto-X ? |
#50
mine are all the same color even with the green still on the back of the hvac. i just like the deep red color of my interior. Also the pic i posted as the finish product of the HVAC was very dark because i found out about a month ago a bulb was burnt out in it making it look so crappy but i ordered new lights so ill take some new pics soon of the progress so far.
#51
ok ok i get it now so you are usin the sand paper on the actual buttons?
#52
not the buttons, the back of the hvac where the green plastic is just give it a swipe or 2 to help the glass paint stick better to it
#53
k my god damn cd cage won't come out i undid all the freakin screws and i can't get the beast out!!! any tricks??
#54
there are 3 screws two on the top corners and one on the bottom middle. but slide something on the right of the cage because there is a hook that will keep it there unless you slide something against it
#55
ah!!! there we go now you're talkin we'll see what happens now...
#56
It's easier for me also, if I turn the ignition to "on" and shift to the "1st" position while the car is NOT RUNNING. Gives you more room to work with.
bLAh
#57
i'm 5 spd styliee... so for me that would be second,fourth, or reverse
#58
#59
the hvac ones
#60
updated pics sorry they're a little dark
