Old 11-04-2007, 06:16 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Sorry but i have no pics but ill try to explain very eaSILY:
Power Wire:
Run the power wire from the battery into a large hole to the left of battery where a bundle of wires go into the fender.
Then run and zip tie it to the cables running to the door you should see a yellow loomed cord going into a grommet. i fit a 4 gauge in it so anything that size or small should be ok.
Push the wire threw the grommet and look by the driver side kick panel and remove it. once removed pull the wire out and run it under the carpet the whole way back to the back seats.
remove the bottom seat and open the top seat enough that you can push the power wire to the desired location.
RCA and Remote turn on wire:
Basically run them from the cd player under the pass. side carpet along the rocker panel to the back seats and hook them up.
Hope this helps
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 11-05-2007, 08:29 PM
Wikedjuggalo's Avatar
Rebuilding
O.k Installed the new stereo and hopefully the sub and amps will be on its way. I had a fun time doing this, as one of the antana cords got stuck under something. and all the wire spicing was fun and I was very proud of myself for installing it myself. I do wanna to thank the person who made that website for installing it, its godly. I was also doing this in the dark and made it 20x difficult.
Word of advise, Don't do it in the dark as holding a flash light and trying to cut wires is fun.
Old 11-05-2007, 08:48 PM
Glad to hear you got the stereo in. Now its just easy stuff, (i had similar experiances with wire stripping long story short i didn't strip the wire i striped my index finger and took a huge chunk off)
Seth
Past subies:
Other toys:
